Question about masking off holes for finishing
Forum topic by ScottStewart posted 08-04-2012 02:37 PM 1245 views 0 times favorited 15 replies Add to Favorites Watch
View ScottStewart's profile
ScottStewart
119 posts in 2101 days
08-04-2012 02:37 PM
Newb question, but I can’t figure out a great answer:
I am making a couple of toy cranes for my kids, and SWMBO has decreed they will be painted. (Ouch) These parts have a bunch of holes for differing axles, and I am trying to figure out how to let the kids paint without messing up my holes. Is there a foam or something you use that is easily removable? I debated using dowels to fill the holes, but thought they would likely get painted in, and when I went to drill them out would egg out the axle holes.
We are using a kid safe acrylic paint we found at hobby lobby if that makes any difference.
Thanks for any thoughts.
Scott
15 replies so far
View Don W's profile
Don W
18686 posts in 2537 days
#1 posted 08-04-2012 03:10 PM
Not seeing the projects this may not work, but can’t you just redrill them?
ScottStewart
#2 posted 08-04-2012 05:36 PM
That is what I will probably have to do, but I was afraid I would egg out the holes doing that. Thanks for the help.
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2826 days
#3 posted 08-04-2012 05:43 PM
Use dowels in the holes
Make sure they are waxed
It also makes it easier to hold while
painting
jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View MNgary's profile
MNgary
298 posts in 2386 days
#4 posted 08-04-2012 11:07 PM
You should be able to use your fingers to twist the drill bit and avoid “egging”. I.e., don’t use a brace or an electric drill, just your fingers and the bit.
-- I dream of a world where a duck can cross the road and no one asks why.
117063 posts in 3546 days
#5 posted 08-04-2012 11:14 PM
Sometimes you can fill holes with tooth picks that have a little wax on them or short pieces of rubber or plastic tubing or plastic straws.
View Sawkerf's profile
Sawkerf
1730 posts in 3038 days
#6 posted 08-04-2012 11:19 PM
You could mark your hole centers with a finish nail before the kids paint. When the paint is dry, use Forsner bits to drill nice, clean, holes.
View racerglen's profile
racerglen
3112 posts in 2750 days
#7 posted 08-04-2012 11:21 PM
Depending on the size of the hole, try Q tips, they may leave some fuzz that neds cleanup, but
they do pull out easliy.
a1Jim’s toothpicks are another goodie, also, again depending on size the bamboo skewers for BBQ that go for about a buck per hundred ?
-- Glen, B.C. Canada
TopamaxSurvivor
18250 posts in 3645 days
#8 posted 08-05-2012 12:22 AM
I would either use waxed dowels or twist a drill by hand.
View Fuzzy's profile
Fuzzy
298 posts in 3958 days
#9 posted 08-05-2012 12:33 AM
Maybe go one size smaller dowel and wrap it with a few wraps of blue tape ???
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View Gatorjim's profile
Gatorjim
217 posts in 2174 days
#10 posted 08-05-2012 12:59 AM
I would think you could use playdough just fill the hole a little lower then the surface then paint it. It should be easy after it dries to get the playdough out of the hole.
-- My theroy in wood working will be. If I'm not enjoying doing it i won't do it.
View HerbC's profile
HerbC
1744 posts in 2829 days
#11 posted 08-05-2012 01:56 AM
Cut pieces of foam backer rod (used by builders to fill cracks before caulking, available at box stores) Use the pieces to fill the holes, remove after painting.
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Gator's profile
Gator
383 posts in 3645 days
#12 posted 08-05-2012 09:16 PM
soda straws..?
How big are these holes ?
-- Master designer of precision sawdust and one of a kind slivers.
ScottStewart
#13 posted 08-05-2012 11:17 PM
they are 3/8 inch for the one I am most worried about. Thank you for all the replies.
View bondogaposis's profile
bondogaposis
4690 posts in 2320 days
#14 posted 08-06-2012 12:15 AM
Just pinch off a piece of pipe insulation, stuff the hole, and pull it out w/ needle nose pliers when done.
-- Bondo Gaposis
View Gshepherd's profile
Gshepherd
1727 posts in 2171 days
#15 posted 08-11-2012 10:38 AM
For the size i think you could stick a few space balls in there and when done push them out….. I did this when my girls made some toy cars and such…...
-- What we do in life will Echo through Eternity........
