Recommended alternative to spraying lacquer for large flat surfaces
Forum topic by FusionHF posted 320 days ago 902 views 1 time favorited 12 replies Add to Favorites Watch
View FusionHF's profile
FusionHF
1 post in 320 days
320 days ago
Topic tags/keywords: finishing large flat surface question modern
Usually I spray clear SW precat lacquer with my HVLP all day long without any issues BUT i have found it virtually impossible to get a uniform finish on large, flat surfaces. (i.e. 4×10 walnut on mdf)
Any suggestions on a good alternative to spraying? Satin/dull rubbed sheen is my desired finished look.
12 replies so far
View Clint Searl's profile
Clint Searl
881 posts in 558 days
#1 posted 320 days ago
I usually use SW CAB Acrylic or NC lacquers with a conventional sprayer. Occassionally, I will brush the first coat or two for rapid build and reduced overspray. Fast work and slight thinning keeps things pretty uniform and without brush marks. Follow-on thined sprayed coats, ending with a final heavy misting of almost straight reducer makes for a uniform finish and even overall sheen. No experience with precat, but works well with the mentioned plain solvent lacquers.
-- Clint Searl.............We deserve what we tolerate
View NiteWalker's profile
NiteWalker
1588 posts in 774 days
#2 posted 320 days ago
I’ve read of some guys rolling it on with a paint roller when big panels were involved.
View bruc101's profile
bruc101
526 posts in 1739 days
#3 posted 320 days ago
Some precats dry to fast and you have to retard them to slow the drying process down. Ask your vendor if they can do it for you.
The faster it dries the less time it has to do any kind of flow-out.
-- Bruce http://plans.testsitem3.info http://www.sawmillgirls.com
View lunn's profile
lunn
130 posts in 505 days
#4 posted 319 days ago
Chech with the auto body paint suppliers. They sell different thinners with different drying speeds. Just thinking !Wonder how the clear coat used on cars whould work on wood?
-- What started as a hobbie is now a full time JOB!
View ArtB's profile
ArtB
17 posts in 348 days
#5 posted 319 days ago
Try Shellac gloss premix, keep a wet edge when spraing. Then wet sand w\ 1200 paper and soapy water, for satin finish.
View Doss's profile
Doss
777 posts in 461 days
#6 posted 319 days ago
Wonder how the clear coat used on cars whould work on wood?lunn
It’s a mixed bag really. Wood that moves a lot is a problem for most automotive clearcoats. Automotive clearcoats move very little (unless they’re designed with flex agents for things like plastic bumpers) and are fairly hard and brittle.
Now, that’s not to say you can’t use them. You just have to think more about the correct application for it… just like any other finish.
Also, automotive clearcoats are generally more expensive than those designed for wood (though some are very similar in composition).
-- "Well, at least we can still use it as firewood... maybe." - Doss
View lunn's profile
lunn
#7 posted 319 days ago
Doss Hadn’t thought about the movement of the wood so rules it out.
View Doss's profile
Doss
#8 posted 319 days ago
Not a problem lunn. Like I said, auto clearcoat will work in some applications. Just like any other finish, they require some thought into the material you’re applying them to, purpose, wear, overall look, etc.
They are usually more expensive since they are formulated to work in a more harsh environment than most wood finishes.
Clint Searl
#9 posted 319 days ago
I have used the old solvent acrylic auto clear coat on furniture with complete success. see the dest and dining table in My Projects for examples. No experience with the current auto clears, but I doubt the any wood moves more than the steel of the hood on a dark painted car under a summer sun, so I wouldn’t hesitate to use the current auto clears on furniture.
View ArtistryinWood's profile
ArtistryinWood
82 posts in 1884 days
#10 posted 319 days ago
Have not tried this technique myself, but i have heard it works very well for large flat surfaces.
Tip – read comments.
http://videos.americanwoodworker.com/video/The-Best-Brush-Ever-A-Paint-Pad;From-the-Editors-of-American-Wo
-- It seem's to me i could live my life, a lot better than i think i am. Andrew, Midland, Ont.
View Joseph Jossem's profile
Joseph Jossem
171 posts in 465 days
#11 posted 319 days ago
I spray 4 coats switching patterns each time of application vertcal horizontal etc.sand in between and last coat real heavy.If that dont work thin it a little might help. gotta make sure your passes overlap each other no misses it willl show up when dry at a angle. hope any of that helps
View AtomJack's profile
AtomJack
1302 posts in 1306 days
#12 posted 319 days ago
Try a slower thinner. Slower is for higher temperature. These are old standbys in the automotive paint industry. I say old because lacquer has been nearly legislated out of existence in California. You can get it in quantity in certain places, and small quantities most places, because it is nonsense to force water-based repair on one fender of a car painted with lacquer. I have also wet-sanded large areas of wood in order to get the sheen and smoothness I wanted, if I had it too dry or overspray. Also, I do as has been mentioned- I run thinner through the gun to clean it and flow out dry spots at the same time.
