| Forum topic by fonzie | posted 292 days ago | 1369 views | 0 times favorited | 55 replies | ![]() |
292 days ago |
Topic tags/keywords: planes hand planes vintage hand planes vintage stanley Hi guys, Long time lurker, first time poster. I’m heading on my first outing to check out what I believe to be some vintage hand planes. Can anyone take a peek at these photos and let me know what to expect, in terms of value, and what I should be cognizant of when purchasing? I’ve got experience flattening and sharpening by own (new) planes, but this is my first time with vintage. I’ve already reviewed this great site, but any other resources you recommend will be welcome. Thanks in advance!
55 replies so far
#1 posted 292 days ago |
OMG, the motherlode. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#2 posted 292 days ago |
Bertha, thanks for the info! Will keep you posted on what I am able to get my hands on! |
#3 posted 292 days ago |
Well, jack, jointer, and smoother. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#4 posted 292 days ago |
I saw that second photo and knew Al would be lusting for the infill. “I’d buy every plane in that picture beside the one in the box.” fonzie, a couple other sites that may help if you don’t get overloaded. The Superior Works has lots of information on Stanley planes. Don W's website also has a lot of good info. Don is an LJ member and I’m sure will see this thread very shortly. Edit: Yep, there he is. I think anytime the word plane pops up on LJ, Don’s spidey sense goes off. Actually, it’s more of a Yoda-esque use of the force. -- "The U.S. Constitution doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself." -- Benjamin Franklin |
#5 posted 292 days ago |
someone anyone push my eyeballs back in my head …. Berthas got em all nailed … -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#6 posted 292 days ago |
Al, may be a little high on the millers falls. I think he’s good everywhere else. If thats a #40 scrub, its worth between $50-$100. Maybe a little more if its in really good shape. Typically a rule of thumb, if its got rosewood its worth a little more than hardwood. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#7 posted 292 days ago |
Wow guys, thanks for all the info. JayT, I’ll check out those links, I have a lot to learn! Don W, thanks for corroborating Al’s assessment. So you mention being in good shape. What should I be looking for to determine that? Rust? Any cracked parts? What are the common failure points that make refurbishing no longer worth it? |
#8 posted 292 days ago |
Don, I was hesitant to attempt to price that MF. I defer to the experts on that one. I forgot about the scrub; it looks like a really nice one. Long blade, tall knob, clean cap; I’m guessing closer to $100 like you say. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#9 posted 292 days ago |
The one in the second photo next to the scrub looks like a Sargent auto-set. I’m thinking those have their fans and can go for decent prices. -- "The U.S. Constitution doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself." -- Benjamin Franklin |
#10 posted 292 days ago |
Look on the underside of the plane where the blade protrudes from the sole. This is the mouth. You don’t want it chipped. Make sure there aren’t any weld marks or cracks. Check to see if the iron it pitted. A broken wooden part isn’t usually such a big deal (with the exception of the scraper, possibly). These are pretty bulletproof planes. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#11 posted 292 days ago |
I think you’re right, JT. I think there’s another sargent block there. The one that looks like stamped steel. I think Don recently rehabbed one of those. The cat is coming out of the bag with sargents. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#12 posted 292 days ago |
In the 2nd photo, the plane in the middle looks like a Sargent auto set plane. I cant really tell but it looks like a #5 size… That one could be worth somewhere in the ball park of 100 dollars… If its smaller size then a #5 then it will be worth more… -- Dan - "Collector of Hand Planes" |
#13 posted 292 days ago |
Crap, I think that bullnose is a Preston. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#14 posted 292 days ago |
Yep, that’s an autoset. . -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#15 posted 292 days ago |
I don’t mind rust, but it will depreciate the value. Rust can be removed if you don’t mind putting in some time. Look for breaks and cracks. (thay can hide well sometimes, so look close) Especially around the mouth, but other areas, the frog often breaks around the adjuster. You will see chips around the sides, but if they are small they typically don’t hurt as a user. Always take the cap off and look underneath. I’ve made the mistake of buying a plane not knowing the blade was broke. Also, you’ll see if the frog is broke that way. Make sure there is life left in the blade. Replacement blades can be had, but figure that cost in the purchase price if need be. Cracked broken or missing wood pieces. I don’t mind buying with any of these defects, but purchase price should reflect the repairs needed. Basically if the metal is all there, wood parts can be recreated. Look at the japanning. Again, it can be replaced if its to bad, but price should be reflected. Look at part 9 of this for restoration advice -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1531 |
3547 |
15771 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2839 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
