| Forum topic by MrRon | posted 295 days ago | 539 views | 0 times favorited | 8 replies | ![]() |
295 days ago |
I am building a CNC router machine and want to use the Bosch Colt router as the router. Please could you give me the dimensions without the base which I won’t be using. The model I will be using is PR20EVS. |
8 replies so far
#1 posted 295 days ago |
don’t have a Colt…. but I know that my local HD has them on display… time for some stealth caliper measurements? -- Matt, Pine is fine, but Oak's no joke! |
#2 posted 294 days ago |
I don’t have the specs but you can call their toll-free customer service at 1-877-267-2499. -- Raymond, Charlotte, NC -------- Demonstrate the difference! |
#3 posted 294 days ago |
You could buy it… Then at least you can measure it while you build and you have it when your Cnc is completed. -- My terrible signature... |
#4 posted 294 days ago |
2 3/4” diameter. -- TJ - Perryville, Missouri |
#5 posted 294 days ago |
One other option, is to not use the base. Make a curved base to hold the router on the side and use two hose clamps to hold the router firm, or make a matching round curved support and cut a slot so you can use a bolt to compress the wood and hold the router in place. Here’s a photo of the way my router moter is held in place on my gunstock duplicator. It’s made with an aluminum support that’s bored to take most router motors and it came with a sleeve to hold the few routers that are slightly smaller. I use a 2 1/2” hp router because the extra power helps remove a lot of wood in a hurry.
-- Hal, Tennessee http://www.first285.com |
#6 posted 294 days ago |
MrRon, I’ve got one. I could measure it tonight for you. If you PM me, I might remember;) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#7 posted 294 days ago |
Why can’t you buy it now and have it on hand? |
#8 posted 294 days ago |
Thanks all. I went to HD and took measurements. Due to monetary concerns, I have to plan all my purchases carefully. If I buy the router now, I won’t have enough money to build the rest of it. The router is the last item I will need, so I need just the dimensions for now to build the mount. |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1535 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
