Joining together 2 pieces of 3/8" teak
Forum topic by will delaney posted 07-31-2012 08:04 PM 3975 views 0 times favorited 12 replies Add to Favorites Watch
View will delaney's profile
will delaney
326 posts in 2663 days
07-31-2012 08:04 PM
Topic tags/keywords: glueing joining together joining
I resawed a piece of Teak and would like to bookmark it for a door. When trying to glue with Gorilla Glue it didn’t make a good bond. Does any LJs have a way to get a strong joint on 3/8 wood. Thanks Will
12 replies so far
View jbschutz's profile
jbschutz
539 posts in 2719 days
#1 posted 07-31-2012 08:07 PM
Will,
I think Gorilla glue has its place, but I would go with Titebond III…. and an eighth inch spline running the length of the joint. Draw it up tight and leave it for 24 hours.
Hope it works for you, John
-- jbschutz www.johnschutz.com
View chrisstef's profile
chrisstef
17428 posts in 3034 days
#2 posted 07-31-2012 08:12 PM
You may want to clean the edges prior to glue up with acetone. The oils in the wood make it tough to glue. Ive had to employ that method when using cypress.
View Clint Searl's profile
Clint Searl
1533 posts in 2388 days
#3 posted 07-31-2012 08:13 PM
I agree with any of the Titebonds. Make sure the dry fit joint is perfect without clamping. Then a spare bead of glue without over clamping. Keep it flat during the cure.
will delaney
#4 posted 07-31-2012 09:00 PM
You’s guys are great! No down time ask a question and you get an answer in real time. John the spline should do the trick. I do have some Titebond and will clean the joint give it another try. Thanks all. Will
View degoose's profile
degoose
7234 posts in 3382 days
#5 posted 07-31-2012 09:30 PM
All of the above… and this is a great place to have questions answered in real time… there is someone around the world awake…
View Cole Tallerman's profile
Cole Tallerman
392 posts in 2212 days
#6 posted 08-01-2012 02:21 AM
Either a spline or use a biscuit jointer with some titebond.
View fussy's profile
fussy
980 posts in 3078 days
#7 posted 08-01-2012 02:29 AM
Be careful with the spline. Sometimes they swell and keep the joint from fitting. If you can, use leftover teak for the spline. Another thing to consider; as edge-grain to edge-grain makes a very strong joint without any help (glues are stronger than the wood or they’re useless), just run your bead and clamp. Use c clamps on the ends to force them to line up, a mallet in the centeer and tighten the clamps in steps. Don’t over tighten.
Steve
View Lee Barker's profile
Lee Barker
2170 posts in 2878 days
#8 posted 08-01-2012 02:33 AM
No one mentioned lacquer thinner or naphtha to get rid of the oils. And I agree; no splines, no biscuits.
Boatbuilders regularly use epoxy on teak with great success. They clean as well, and definitely underclamp.
Kindly,
View handi's profile
handi
141 posts in 4467 days
#9 posted 08-01-2012 10:21 PM
Wiping the edges with acetone is critical. The teak has oil in it that will ruin even an epoxy bond.
I like to use “V” bit sets for edge gluing thin panels. The V gives more glue surface and keeps the joint aligned so there is far less need for flattening afterwards.
You can see the process in a video on my website. Scroll down the “Skill Building” page, it is About the 5th one from the top, Aligning Thin Edges for Glue Ups.
Ralph
-- Watch Woodcademy free on Amazon Prime! www.woodcademy.com
View MonteCristo's profile
MonteCristo
2099 posts in 2216 days
#10 posted 08-02-2012 04:01 AM
The Gorilla glue should have worked but maybe you didn’t dampen the surfaces first ? I would have thought Titebond was not the best option given the naturally high oil content of teak. Also, clamping boards only 3/8” thick requires some care as they could easily flex and compromise the glue joint. You should use some scrap wood strapping to prevent this.
View usnret's profile
usnret
184 posts in 2535 days
#11 posted 08-02-2012 05:33 AM
I used Titebond III on teak for edge gluing and gluing end grain and it has held up for 8 months now. Before you glue the edges wipe them down with denatuted alcahol or mineral spirits to remove any natural oils from the wood.
-- Chief Petty Officer USN(RET) 1991-2011
will delaney
#12 posted 08-02-2012 11:55 AM
There definitely is not one way to do this. It seem like everyone has had successes with different technique. There seem to be one common thread, to clean the joints of the natural oils. I did use Titebond and hopefully it will hold. If I were to do it again I would of made two panels. Time to research rail and stile bit sets. Thanks for the info. I will post the project when done. Will
