Anybody done any backyard foundry and sand casting parts?
Forum topic by Loren posted 07-31-2012 05:47 PM 1615 views 0 times favorited 9 replies Add to Favorites Watch
View Loren's profile
9964 posts in 3555 days
07-31-2012 05:47 PM
I’m looking into this. I don’t know anybody who has done
it personally. I’m looking into casting furniture components.
Anybody have comments on how large you can go in terms
of size and weight of castings before doing it yourself with
a propane foundry becomes impractical?
9 replies so far
View Deycart's profile
Deycart
444 posts in 2164 days
#1 posted 07-31-2012 06:25 PM
I have done some casting for a while in brass and aluminum. Aluminum can be done really easy. Brass can be a challenge. Iron… Good luck. That’s major work. If you want some info check out http://www.backyardmetalcasting.com/
You could easily cast your own brass knobs and such. Larger the casting the harder it gets. There is also quite the learning curve. I have had good success with lost foam casting. Sand casting takes too much time and effort and is easily messed up. Plus you can get everything for lost foam at your local home store. Also don’t waste your time on melting cans if you go the aluminum route. Its just a big mess and you get very little metal. If you want a fairly cheap source of brass go to your local thrift store and buy up some old brass candle sticks. Just check them with a magnet first to make sure they do not have a steel core.
View Mainiac Matt 's profile
Mainiac Matt
7665 posts in 2235 days
#2 posted 07-31-2012 08:23 PM
no I haven’t…. but I always thought it sounded very interesting…. so I’ll be watching.
-- Pine is fine, but Oak's no joke!
View Grandpa's profile
Grandpa
3259 posts in 2582 days
#3 posted 07-31-2012 10:08 PM
When I was in school we cast some aluminum. I graduated 42 years ago and it was before that time. I do have simited experience though and I don’t remember it being that difficult. Of course we had all the correct items on hand for making a casting. Nothing was makeshift.
View David Kirtley's profile
David Kirtley
1286 posts in 2905 days
#4 posted 07-31-2012 11:43 PM
My personal casting experiences was what you could measure in ounces. Oddly enough, I have only done investment casting and never tried sand casting. Would like to try in in the future.
http://www.foundry101.com/ Has some info and some small furnaces as batteries included kits. Budget Casting Supply is a one stop shop if you are going to build your own. They are not the cheapest but lots of the places that sell stuff don’t like dealing with hobbiest quantities. Shipping fees get terrifying quickly.
The problem is not the melting. You can melt a bathtub full. The real trick is getting it to the mold and pouring it. I wouldn’t want to go more than about 10lbs single handed and would feel more comfortable under 5lbs. More than 20lbs and you are better off with some kind of gantry to move it around. That is a big chunk of hot molten death if it gets out of hand.
View shipwright's profile
shipwright
7895 posts in 2705 days
#5 posted 08-01-2012 04:10 AM
I’ve cast several lead keels in shop or in my back yard using one or two tiger torches as heat source..
The largest was 9500 lbs but lead doesn’t require as much heat as most metals.
The main concerns in large pours are
1) planning for the correct amount of shrinkage (1/8” per foot for lead as I remember)
2) pouring slowly enough to be able to keep the pot liquid while adding more solid material but fast enough to keep a “wet edge” in the mold. I know that’s do-able with lead but ????
What do you want to cast?
#6 posted 08-01-2012 04:32 AM
I’m looking at casting table legs so there needs to be some
strength and stiffness with not too great a cross-section.
TopamaxSurvivor
18195 posts in 3583 days
#7 posted 08-01-2012 06:05 AM
What ever you do, be cautious about moisture! Water expands at a ration of 1600:1. Trust me, you don’t have that much room! A drop of water will empty a 20 pound lead pot ;-(
shipwright
#8 posted 08-01-2012 10:52 PM
Sorry Loren,
I’m not likely much help then.
View Bertha's profile
Bertha
13508 posts in 2600 days
#9 posted 08-02-2012 01:56 PM
Loren, you might want to contact Paul Hamler.
http://hamlertools.blogspot.com/
He does a lot of smallish scale (lol) lost wax casting and I know he knows a lot of larger scale guys. He could probably put you in touch with them. He’s a real friendly and approachable guy. Knows everything there is to know about engineering and machining. Good luck!
