Help with lightening up figured walnut.
Forum topic by riooso posted 07-31-2012 03:25 PM 926 views 0 times favorited 5 replies Add to Favorites Watch
View riooso's profile
riooso
38 posts in 2608 days
07-31-2012 03:25 PM
I have some highly figured and burled walnut that I have sliced and am using as veneer. I have been using General Finishes Arm-R-Seal which a Tung oil and urethane resin. I don’t use any stain in the process.
The walnut comes out very dark and I would appreciated some help figuring out a way to end up with more of the walnut grain showing. Either I need to lighten before finishing or go to a different finish but even a coat of just Poly-urethane is quite dark.
Thanks in advance,
Richard
5 replies so far
View Bill White's profile
Bill White
4901 posts in 3922 days
#1 posted 07-31-2012 04:20 PM
Be aware that walnut will lighten with age. I wouldn’t do anything but let it age well. Oil based finishes will “amber” the wood. Water based won’t.
Bill
-- bill@magraphics.us
riooso
#2 posted 07-31-2012 04:50 PM
Thanks for the tip.
R
10242 posts in 3610 days
#3 posted 07-31-2012 04:53 PM
Super-blonde shellac is very transparent and ambering is
not noticeable. Oils always darken wood in my experience.
117060 posts in 3539 days
#4 posted 07-31-2012 05:10 PM
As Bill said walnut lightens with are but it you want it to lighten up now you can place your wood in direct sunlight,but you must keep a close eye on it.
riooso
#5 posted 07-31-2012 05:30 PM
How long would it take on 100 Degree low humidity heat to lighten Walnut?
R
