using treadmill as a base for drum sander?
Forum topic by moshel posted 49 days ago 164 views 0 times favorited 7 replies Add to Favorites
View moshel's profile
moshel
129 posts in 135 days
49 days ago
Topic tags/keywords: drum sander question
Hi everybody,
all this DIY drum sanders got my appetite going. However, getting the parts and the motor here is very expensive and hard. I was thinking about getting a used treadmill (they are pretty cheap) that usually has torn belt and salvaging the motor and drums from it. Being a very unfit person, I was wondering if anyone there that has a treadmill or knows about treadmills can verify if the motor would be suitable or any other comment.
-- The woods are lovely, dark and deep, but I have promises to keep...
View motthunter's profile
motthunter
1172 posts in 250 days
48 days ago
I don’t think that this motor will work. Might be too weak. There must be a way for you to order an appropriate motor from an Internet company.
-- making sawdust....
moshel
48 days ago
some of the treadmills have 2hp motors. i might be able to get the motor, but all the stuff around it will be harder.
1822 posts in 472 days
48 days ago
They are probably your cheapest source of variable speed motors and the controller.
If you have a sports equipment repair store near you you might want to give them a call . The one here had dozens of wrecked machines when I went there on a differnet matter.
View Mark Shymanski's profile
Mark Shymanski
428 posts in 163 days
48 days ago
Hmmmm, some of these are build on pretty rugged frames also. That might be a good platform to build up from. The end rollers might be too small of a circumference to make the sanding drum from but the mounts, bearings etc could be re-purposed with a little cutting and welding…. after I build my lathe :-) I think this is the next tool to build…thanks for the idea about the treadmills!
-- ....next big purchase is wood for the next project, Mark
View John Gray's profile
John Gray
599 posts in 336 days
48 days ago
Good idea now I’ll be watching used treadmills…..as if I need another project right now.
moshel
48 days ago
i wonder… some of these also have electronic height adjustment. but i think its not accurate enough. basically i think that every treadmill has a drum sander lurking inside, waiting to be found…
Thanks for all your replies. anyone knows whats the rpm of the motor on treadmills?
View GaryK's profile
GaryK
8411 posts in 439 days
48 days ago
Might be interesting to look into this for a stroke sander.
Check out this Grizzly one: http://www.grizzly.com/products/Stroke-Sander/G5394
Bookmark And Share This Page
