Sanding inside corners
Forum topic by ScottStewart posted 07-31-2012 01:24 AM 3763 views 0 times favorited 6 replies Add to Favorites Watch
View ScottStewart's profile
ScottStewart
119 posts in 2007 days
07-31-2012 01:24 AM
So does anyone have any great ideas for sanding inside acute angles? I have an inside 45 degree corner on the sides of a toy crane. It’s endgrain, so I don’t have to worry as much about my direction. Maybe cut the opposite block and adhere sandpaper to it? There probably is an easy way to do this, but I dont’ knwo what it is.
Thanks
Scott
View MonteCristo's profile
MonteCristo
2099 posts in 2063 days
#1 posted 07-31-2012 03:12 AM
You’ve likely considered this option already but sanding before assembly is the usual way out of these pickles.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3058 days
#2 posted 07-31-2012 03:19 AM
I use emery boards. The kind used on fingernails. You can get them in assorted grits and they work very well.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
ScottStewart
#3 posted 07-31-2012 04:06 AM
Monte, it’s all one piece or else that would have been my plan. I like the emery board plan, I also tried a piece cut at a complementary 45 degrees. This is the piece I am trying to sand…
http://www.shopsmithhandson.com/archives/nov_dec00/html/crane_side.htm
Thanks for the help.
View BertFlores58's profile
BertFlores58
1685 posts in 2797 days
#4 posted 07-31-2012 05:34 AM
Have you ever tried a dremel with extension? The one being used for etching glass, carving and others. There is an assorted bits for it. If the dentist can sand, grind on a tooth without scratching the tongue and so you can.
-- Bert
View rance's profile
rance
4255 posts in 3035 days
#5 posted 07-31-2012 05:42 AM
Power tool rule! :) I think I might try my Fein Multimaster. Or one of the knock-offs.
View Vicki's profile
Vicki
1088 posts in 3219 days
#6 posted 08-03-2012 02:16 AM
I have an assortment of diamond sanding files and small files from Harbor Frieght. I also have plastic sanding sticks with sanding belts on them here’s one source:
http://www.micromark.com/micro-sanding-wand-set,7760.html
I use the nail files, emory boards, sanding string and I have a sanding strip I can put on my scroll saw. I also have used sand paper wrapped around small scraps of wood. My favorite is my Dremel multimax with the triangle sander or a sanding finger that I adapted from a Rockwell sanding finger.
-- Vicki on the Eastern Shore of MD
