is a thickness planer the tool?
Forum topic by poser516 posted 47 days ago 114 views 0 times favorited 4 replies Add to Favorites
View poser516's profile
poser516
13 posts in 48 days
47 days ago
Is the proper way to get lumber flat by using a jointer to flatten one side and then using a thickeness planer to match the joint on the other side?
To get a piece of stick to have two flat, paralell sides,are a thickness planer and jointer the tools for the job? i have nobody else to ask, so thanks for your help.
View Dusty56's profile
Dusty56
1024 posts in 137 days
46 days ago
Yes , that is correct,,,joint one side flat and then plane the other side : )
-- Dusty56@comcast.net
8549 posts in 271 days
46 days ago
A thickness planer will keep two sides parallel. If the reference side is not flat the planer will simply follow the curve of the reference side so if you want lumber that is both flat and parallel then you need to create a flat reference side by taking it through a jointer before planing the lumber.
View motthunter's profile
motthunter
1166 posts in 248 days
46 days ago
you guessed it.. get one side perfect ont he jointer and the other will follow
-- making sawdust....
poser516
13 posts in 48 days
46 days ago
thanks everybody.
Bookmark And Share This Page
