Calling all Refurbers - Fasteners for oak... American white oak that is
Forum topic by 404 - Not Found posted 07-30-2012 03:50 PM 1429 views 0 times favorited 1 reply Add to Favorites Watch
404 - Not Found
2544 posts in 2878 days
07-30-2012 03:50 PM
In the pipeline is the 2nd fix for an attic conversion – skirting boards, architraves, and a staircase – all in American white oak. Question is, what type of fasteners to use for Am white oak?
Skirting boards I intend to screw and plug – they’re not an issue, I’m more concerned about architraves and the balluster infills for the staircase – are yellow passivated nails from an air nailer suitable or should I use brass?
Don’t want to take any chances on steel nails reacting with the oak and leaving a black halo – is this even an issue with American white oak as it has a lower tannin content than European oak?
Any advice would be appreciated.
1 reply so far
View Post_Oakie's profile
Post_Oakie
84 posts in 2062 days
#1 posted 07-30-2012 05:54 PM
Once the white oak is kiln dry, you shouldn’t have any problem with blue stain. If you want to be extra sure, use stainless steel or galvanized nails. When I cut white oak on my portable saw mill, even a brief pause in the cut will create a blue streak in the wood where the bandsaw blade was, though it planes out easily.
-- Good judgement comes from experience. Experience comes from bad judgement.
