Using a Forstner bit to drill aluminum plate
Forum topic by MT_Stringer posted 07-30-2012 03:36 AM 5752 views 0 times favorited 11 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3183 posts in 3468 days
07-30-2012 03:36 AM
It may never work again, but using a Forstner bit, I was able to drill a 1/2 inch hole in a Rockler router table insert plate (1/4 inch aluminum).
Previously I had drilled a hole in the insert so I could make adjustments to my Bosch 1617 Router from above the table. Well, it was off a little. Today, I was able to drill another hole just off-center from the first which worked out perfect. First chance I get, I will test the bit. If it doesn’t work properly, I will have to replace it. I am just glad to have the access to the router. Previously, I could get my allen wrench into the adjustment socket at an angle but it was a struggle.
I used the slowest speed on my drill press to do the drilling.
11 replies so far
View Loren's profile
10477 posts in 3885 days
#1 posted 07-30-2012 06:14 AM
I tried to do that last month…. it didn’t work well but I’m
sure you used a better quality Forstner bit. Mine are
real cheapies.
View harvey4804's profile
harvey4804
120 posts in 2919 days
#2 posted 07-30-2012 06:59 AM
As a waterjet programmer at a precision welding and machine shop… the sound of this makes me cringe! But at least it worked out for you!
-- Ryan, FRMR HMM165 - HMX1 01-10
View tyskkvinna's profile
tyskkvinna
1310 posts in 3223 days
#3 posted 07-30-2012 01:16 PM
The tool shapes for aluminum are pretty similar to wood. If you took it gentle, it should be just fine.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View Alexandre's profile
Alexandre
1417 posts in 2428 days
#4 posted 07-30-2012 01:24 PM
I have twist bits from 1/16 to 3/4…. So I hop I never need to.
Didn’t you have a Hole saw?
-- My terrible signature...
View NiteWalker's profile
NiteWalker
2738 posts in 2814 days
#5 posted 07-30-2012 06:03 PM
The key reason he used a forstner, I believe, is that he had to drill another hole off-center to an existing hole. Not many bits besides a forstner will let you do that.
MT_Stringer
#6 posted 07-30-2012 06:16 PM
The bit I used was one from the Harbor Freight set. I took it slow and it simply shaved of the aluminum as it wood a piece of wood. A twist bit would have tried to center itself in the original hole. I didn’t want that. The forstner bit cuts from the outside of the hole so there was no grabbing, jerking or shuddering.
1/2 inch hole saw? Nope, don’t have one.
Here is a pic. You can see part of the original hole which I did a bad job of laying out to center it over the adjustment socket. The new one is drilled in good position and easy to use.
Alexandre
#7 posted 07-30-2012 07:18 PM
Ohhhhh… I see….
View DIYaholic's profile
DIYaholic
19741 posts in 2912 days
#8 posted 07-30-2012 08:35 PM
Many folks over at the cnczone use WW bits in their homemade DIY cnc routers to work aluminium. You need to take very lite cuts and use a lubricant (cutting oil) such as WD40.
tyskkvinna
#9 posted 07-30-2012 09:22 PM
WD40 is great with aluminum!
View bondogaposis's profile
bondogaposis
5151 posts in 2588 days
#10 posted 07-30-2012 10:05 PM
I tried drilling brass w/ Forstner bit, it was a very slow process and I don’t think I would do it again, perhaps a brad point would be a better choice.
-- Bondo Gaposis
View oldnovice's profile
oldnovice
7380 posts in 3605 days
#11 posted 07-30-2012 11:32 PM
The problem with twist drills in thin stock (metal) is that the holes are not really round. There must be a relationship between the spacing of the drill bit flutes and the material thickness.
I happen to have an old sheet metal punch that can punch up 1/16” thick aluminum, up to 3/8” diameter …. after that it’s the drill press.
