Help with sharpning chisels
« back to Hand Tools forum
Forum topic by Bryon McGowan posted 296 days ago 463 views 0 times favorited 6 replies Add to Favorites Watch
View Bryon McGowan's profile
Bryon McGowan
36 posts in 1414 days
296 days ago
Topic tags/keywords: question
I am new to chisels and newer to sharpning. The one question when using a flat grind do you need a micro bevel
-- God is great beer is good and people are crazy
View Loren's profile
4877 posts in 1816 days
#1 posted 296 days ago
No. You don’t need it but it makes polishing the steel adjacent
to the edge easier for people who are learning.
I usually hollow grind chisels and plane irons and then hone
as with a flat grind with the high spots touching the stone.
I freehand it. I have jigs but learned to do it without.
Depending on my mood I might lean-in a bit and add a tiny
micro-bevel. The effect is of polishing the whole bevel
but there appears to be a rounding at the edge where
the polish is perfect and further back it is not perfect.
I might ask (in order to better advise you) what sharpening
gear do you have?
View paratrooper34's profile
paratrooper34
698 posts in 1120 days
#2 posted 296 days ago
Hi Bryon, welcome to the world of sharpening.
Do you need a micro bevel? In short, no. The micro bevel is mainly used for ease of sharpening and polishing. Some use micro bevels to manipulate the effective angle such as with plane blades. Some chisels, Japanese, are recommended to be sharpened without one.
The bottom line is the chisel with a micro bevel is easier to hone as the surface area required for honing is greatly reduced with the micro bevel. That equates to less time honing and less materials expended getting there.
Good Luck!
-- Mike
View ajosephg's profile
ajosephg
1719 posts in 1729 days
#3 posted 296 days ago
It all depends on your ability to hold the chisel at the proper angle. Many woodworkers are able to do that successfully.
However, I am not one of them so I bought a Veritas MK.II and use it with the Crazy Sharp system.
-- Joe
View MonteCristo's profile
MonteCristo
2060 posts in 356 days
#4 posted 296 days ago
Some of the steels used these days in cutting tools are pretty darn hard and a microbevel can be a real time saver when honing. The downside, of course, is that this microbevel will grow in size with each successive honing and you will either have to choke down the extra honing time or re-establish the primary bevel and start again. It’s up to you how frequently you do so.
View knockknock's profile
knockknock
47 posts in 341 days
#5 posted 295 days ago
MonteCristo’s downside of eventually having to re-do the primary bevel, is why I don’t use a microbevel. I don’t have a bench grinder, so the thought of doing a primary bevel by hand is not very appealing. Instead, I sharpen/hone frequently with fast cutting stones and finish with a strop.
Bryon McGowan
#6 posted 295 days ago
Thank you for all the help I knew that I would get good sound infomation.
