Toy wagon
Forum topic by Peteyb posted 07-28-2012 08:14 PM 1994 views 0 times favorited 5 replies Add to Favorites Watch
View Peteyb's profile
Peteyb
131 posts in 2432 days
07-28-2012 08:14 PM
I am looking to build a red ryder look alike wagon but I am having a hard time to find the hardware as the wheels to find it. Any suggestions?
5 replies so far
Gerald Thompson
855 posts in 2111 days
#1 posted 07-28-2012 11:54 PM
Try this:Thomastoys@charter.net
810-629-8707
-- Jerry
View William's profile
William
9949 posts in 2719 days
#2 posted 07-29-2012 01:13 AM
The last time I built a wagon I got the axles and wheels at Home Depot. They were in the lawn mower parts department.
View felkadelic's profile
felkadelic
217 posts in 2417 days
#3 posted 07-29-2012 01:20 AM
Are you looking to build one the same size as the real thing, or larger or smaller?
View derosa's profile
derosa
1572 posts in 2712 days
#4 posted 07-29-2012 01:41 AM
Check out this link http://www.thewoodcrafter.net/proj/prpics/p7_2.jpg
For a modern application I would pick up a set of 4 pneumatic wheels with tires from harborfreight, get threaded rod from the local hardware store that just fits them, 8 spacers, 4 lockwashers, and a piece of pipe that just fits over the threaded rod. The pipe cut at just the right width will keep the wheels properly spaced on the threaded rod while a washer on each side will allow the wheels to turn freely. Build the rest of the wagon as the diagram shows.
Instead of the steels rings you could either do a large cartridge bearing like a bicycle bearing or woofcraft has small lazy susan bearing sets that would probably be better.
-- --Rev. Russ in NY-- A posse ad esse
Peteyb
#5 posted 07-29-2012 02:02 AM
William: I will have to check there and see what I can find.
felkadelic: I am looking to build one about the same size and look very similar. I might change it a different color but that might be about it.
