I'd like input on a zero clearance insert
Forum topic by Tenfingers58 posted 295 days ago 744 views 0 times favorited 15 replies Add to Favorites Watch
View Tenfingers58's profile
Tenfingers58
56 posts in 844 days
295 days ago
I’d like to make several zci’s for my tablesaw. For my saw they need to be 17/32 thick. Instead of leveling screws, I plan to make them the thickness of a playing card thinner and glue rare earth magnets into holes drilled into the bottom with the magnets protrudeing the thickness of a playing card bringing them flush with the table.
Any reason not to use magnets to hold the zci in place? Seems most saws just use gravity / maybe some friction to hold them in place.
What material would be best for them? It’s muggy now ‘till the end of summer and I don’t want them to shrink this winter to be able to move around in the recess of the tabletop.
Can UHMW plastic be sanded to thickness in a drum sander?
If I take the Melimine off one side in the thicknessing operation will it warp?
Could I seal the bare side with shellac or poly?
Is there a better material that I haven’t considered?
15 replies so far
View cabmaker's profile
cabmaker
1022 posts in 975 days
#1 posted 295 days ago
solid surface coutertop material (ie: corian)works well. Easy on cutting tools and stays constant.
View MrUnix's profile
MrUnix
256 posts in 365 days
#2 posted 295 days ago
I make them out of plastic cutting boards (polyethylene or HDPE) found at wallyworld or the dollar store for way cheap, particularly if you find them on sale.. you can usually find them just the right thickness and one board will make several inserts.
-- Brad in FL - To be old and wise, you must first be young and stupid
View cutworm's profile
cutworm
684 posts in 959 days
#3 posted 295 days ago
I use 1/2” MDF. I fasten mine down. Don’t know if it’s necessary.. I usually make 10 or so at a time while I have everything out. Stash them in the cabinet.
-- "Actions speak louder than words but not nearly as often." - Mark Twain
View gfadvm's profile
gfadvm
6611 posts in 856 days
#4 posted 295 days ago
Most inserts have some sort of tab or pin on the edge furthest from the front which keeps it from lifting and becoming airborne if the back edge of the blade catches it. I think this is an important safety feature that I incorporated in all of my ZCIs.
View Sawkerf's profile
Sawkerf
1776 posts in 1234 days
#5 posted 295 days ago
I use scraps of 1/2”, prefinished, baltic birch. I cut them to shape and do a bit of sanding to get a good fit (not too tight and not too loose). I don’t bother with leveling screws – if one is a little “off” some sanding or a bit of duct tape brings it to where it needs to be.
After I make the first cut (raising the blade), I bore a largish hole at the back of the kerf. This seems to help get more DC airflow at the rising blade gullets. Not perfect, but it seems to keep some sawdust off of the table.
Tenfingers58
#6 posted 294 days ago
So, it seems like most any man made material would work well for a zci.
I seems to me that the magnets would hold the zci down, unless you were intentionally trying to dislodge it.
I saw on stumpys website he has holes alongside the blade. I thought of putting a baffel to divert the incoming air (suction from the dust collector) through the gullets between the teeth to help keep the sawdust from blowing back in your face. Maybe in addition to Sawkerfs idea of a hole in the back of the slot?
Thank you all for your ideas.
View CueballRosendaul's profile
CueballRosendaul
217 posts in 306 days
#7 posted 293 days ago
Don’t use plexiglass. It gets brittle when thin and chips if you drop it. Looks cool when it’s new, but gets scratched up fast. My next batches will be MDF with laminate countertop material. I like the thought of magnets, but mine is thin and uses screws. Post them when youre done. I’d like to see how they turn out.
-- Matt CueBall Rosendaul. I don't think I've ever had a cup of coffee that didn't have cat hair or sawdust in it.
Tenfingers58
#8 posted 293 days ago
I went to Woodcraft yesterday to get magnets. I arbitrarily decided that 3/8ths would be about right. Of course they were out. So i bought 1/4 and 1/2 inch, 3/8 was a guess anyhow. I won’t get any shop time ‘till wednesday or thursday, so I’ll let you know then how it turns out.
Do your inserts warp with laminate on just one side? Or dosen’t MDF expand that much with humidity?
I’m hoping to find a plastic that power sands well. So I can run it through the drum sander to flush it with the table.
View Charlie's profile
Charlie
671 posts in 452 days
#9 posted 292 days ago
My table saw has the magnets mounted in the recess for the ZCI. So my inserts are held in with magnets. I put t-nuts into the bottom of my ZCI and use little allen set screws to adjust height. The t-nuts are centered on the magnets and even if I raise the ZCI off the magnet a little using one of the leveling screws, it has never moved.
Despite cleaning out the recess whenever I remove a ZCI, every once in a while I need to tweak a leveling screw.
View lumberjoe's profile
lumberjoe
2394 posts in 414 days
#10 posted 292 days ago
My local woodcraft started carrying phenolic coated plywood. I picked up a half sheet of 1/4” that I am going to use to make a lot of ZCI’s. The first batch will be for different dado sizes. The next set will be for different blades. I will need to cut for the riving knife, which will be tricky.
Can you use a ZCI for angled cuts? I use my standard Insert but get more tear out that I would like on miters
-- http://www.etsy.com/shop/KandJWoodCrafts
Tenfingers58
#11 posted 292 days ago
Lumberjoe,
I assume you mean by angeled cuts that the sawblade is tilted. You can use a ZCI in this application but you need to cut the slot at the angle of bevel that you want. That is part of the reason that I want magnets to hold the ZCI in place. To make it easy to change. The insert that came with my saw fits so tight you need to get under it an tap it up and out with a hammer.
I like the idea of the phenolic ply except I plan to sand to table height after mounting the magnets. I wonder if I could find emery paper that would fit on my thickness sander to sand the magnets instead of the top surface. I don’t much like the idea of magnetic dust in the sander though.
Did they have the phenolic ply in 1/2” then I could glue the magnets 1/32nd proud to be flat with the table.
View harvey4804's profile
harvey4804
98 posts in 848 days
#12 posted 292 days ago
I’ve got some scrap 1/2” Glass Epoxy Laminate “G10” sitting in my office at work that I’m gonna WJ cut into ZCI’s.
-- Ryan, FRMR HMM165 - HMX1 01-10
View GarageWoodworks's profile
GarageWoodworks
311 posts in 322 days
#13 posted 292 days ago
Use a screw at one end and dial in a nice friction fit. Forget the magnets.
-- Subscribe on YouTube: http://www.youtube.com/user/GarageWoodworks?feature=guide
View knotscott's profile
knotscott
4181 posts in 1541 days
#14 posted 292 days ago
UHMW is too prone to warping and it flexes, making it a poor choice for something as large as a TS insert. Phenolic and birch ply are both better materials IMHO.
lumberjoe
#15 posted 291 days ago
Tenfingers58, That is what I meant. The phenolic plywood is really nice. You can get it in any nominal plywood thickness. My saw actually has leveling screws that I can adjust. I need to figure out a way to put a tab on the back as gfadvm suggests.
My saw also has a magnet in the front already, so I am just going to inset and epoxy a washer in the bottom to make contact with the magnet.
