Any ideas on how you might cut/inlay this?
Forum topic by Angela posted 07-26-2012 05:39 PM 2242 views 0 times favorited 13 replies Add to Favorites Watch
View Angela's profile
Angela
205 posts in 3133 days
07-26-2012 05:39 PM
Topic tags/keywords: question ideas inlay craving
A friend has asked me to make him a small coffin for his ashes. It’s made from Cypress wood, which I’ve never worked with before and hopefully will never again because it’s so soft and dents from anything. He wants of his cross inlayed in the top but only about half the depth of the cross.
So far the only methods I though of is to outline the cross, use a Dremel tool and hand cut the wood out. The other way is to photocopy the cross and cut a template on the scroll saw, but I don’t think I’m that good with a scroll saw to make the template that good.
Any ideas how you might do this?
I own a Dremel, a Bosch handheld router and some chisels but no real carving tools. Also the string will be removed.
Thanks for any ideas
Angela
-- www.WoodWorkersWebsite.com - Helping other woodworker's
13 replies so far
View HerbC's profile (online now)
HerbC
1792 posts in 3097 days
#1 posted 07-26-2012 06:04 PM
Make a template, use a guide bushing on the router, perhaps one of the bushing sets for doing butterfly inserts…
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View dhazelton's profile
dhazelton
2805 posts in 2534 days
#2 posted 07-26-2012 06:24 PM
Is the cross wood? You could affix it with hot glue or epoxy to a board and run it through the bandsaw vertically against the fence. Then epoxy it down. You’d have the look of inlay without removing any base material.
Angela
#3 posted 07-27-2012 07:40 PM
Thanks for the ideas. I suggested to him before about gluing it on instead but he wanted me to try it anyways even if I screw up. Also he would never let me cut the cross or doing anything like that. It means more to him than I could ever understand. But thanks. Well we’ll see what happens
Angela
View RS Woodworks's profile
RS Woodworks
533 posts in 3489 days
#4 posted 07-27-2012 07:46 PM
A router with a template will not get you anywhere near close enough in the corners. And glueing it on is well, a little cheesy for such a monumental project.
There is no reason why you cant’ inlay that. Use a small router, sometimes called a laminate trimmer. A bit no bigger than the smallest width on the cross should be used. Use a sharp pencil or sharp awl to outline the cross on the wood. Remove the bulk with the fine router bit. Then clean up the remainder with a fine sharp chisel. Take care and take your time and it will turn out great.
The first time I inlayed butterflies (not dutchmen, but actual butterflies cut out of birdseye maple) I cut the recess on a scrap of wood to test my fit first. That also gave me a bit of experience to do it on the real wood (which was purpleheart).
Good luck!
Ryan
-- I restore the finest vintage tools! If you need a nice plane, saw, marking tool or brace, please let me know!
View FirehouseWoodworking's profile
726 posts in 3510 days
#5 posted 07-27-2012 07:50 PM
That might be a fun project to practice with. Since you’re hesitant about scroll sawing out a pattern, here’s what I’d do:
The round, central part of the cross would be a Forstner bit of the appropriate size, drilled out to the appropriate depth. If you don’t have a Forstner bit, careful work with a sharp spade bit can do the trick.
Next, trace out the outline of the cross and clamp guides on either side of each leg of the cross. Using a straight bit, hog out a majority of each leg of the cross to the appropriate depth.
Next would be a razor knife scoring the outline of each leg of the cross, a little deeper each time, for a nice, crisp outline. Use a chisel to pare away what wood you have scored, or turn the razor knife sideways and do it that way.
Have fun. Good luck! Cheers!
-- Dave; Lansing, Kansas
Angela
#6 posted 08-23-2012 08:44 PM
Thanks everyone for their imput.
OK, I finished and it came out perfect. I wanted to share how I ended up doing it. I just happened to run across a recent article in Fine Woodworking magazine that had a photo of a Dermel in a base made by Stewart-MacDonald. After doing a search online I located the base and some very small router bits that would fit in a Dermel. I outline the cross on the wood then used the base and several different small router bits and routed out the area. The base held it steady and maintained the dept of the cut. It allowed me to clearly see what I was cutting and the small router bits were amazing strong but very small. I slowly worked my way to the edges so the cross would fit tight.
16281 posts in 4456 days
#7 posted 08-23-2012 08:48 PM
Excellent job!!!
View waho6o9's profile
waho6o9
8539 posts in 2814 days
#8 posted 08-23-2012 08:54 PM
Amazing, very good job Angela.
View gfadvm's profile
gfadvm
14940 posts in 2927 days
#9 posted 08-24-2012 01:29 AM
If you routed that freehand, you now qualify as a “Master Router”!
View JarodMorris's profile
JarodMorris
167 posts in 2613 days
#10 posted 08-24-2012 02:57 AM
I’ve often had an idea but have not had a chance or need to see if it would work. In watching my kids play with play dough one day, I thought, “Oh, I could take something, press it into play dough, let it dry and have a template to use for a 1:1 or whatever. I also thought about using something like this, or clay, or whatever, to hold my wrenches and other tools in place when I get around to making a tool box for my garage. It would be perfect to hold my tools and know exactly where they go without having to trace around them.
Any one else tried this before or something similar?
-- Dad: Someone was supposed to pick up his toys! Son: My name isn't "Someone".
View Loren's profile
10477 posts in 3885 days
#11 posted 08-24-2012 03:07 AM
That worked out nicely. Well done.
View ChuckC's profile
ChuckC
843 posts in 3172 days
#12 posted 08-24-2012 05:35 AM
You did a very good job on this very special project.
View huff's profile
huff
2828 posts in 3522 days
#13 posted 08-24-2012 04:02 PM
Angela, Not only did you do a superb job with your inlay, I want to compliment you on your choice of grain pattern for the top. The grain looks like the top grew around the cross. Great job.
-- John @ http://www.thehuffordfurnituregroup.com
