Cypress, What kind of finish?
Forum topic by Blackie_ posted 302 days ago 850 views 0 times favorited 10 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
1666 posts in 684 days
302 days ago
I am about to install a room wrap wall to wall shelving, wood choice is Cypress, it will have a rear wall support and a front support to keep it from sagging, It will be up high maybe a foot off of the ceiling so only the bottom of the shelving boards will be visiable, should I go ahead and finish both sides? Also need to know what kind of finish would work best, was hoping for some ideas, I want the natural beauty of the of the wood to show without changing the color to much, if anything just making it stand out more, also if possible something that doesn’t take long to dry.
The Pic shown here is an Oak shelving unit, not mine just showing the design I will be using.
Thanks
Randy
aka Blackie
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
10 replies so far
View Roger's profile
Roger
9192 posts in 976 days
#1 posted 302 days ago
I think you should finish both sides. I think BLO before a clear would help bring out the grain, but, that would take a day or more, depending how quickly the Cypress absorbs it. I too, am curious as what others will say and/or suggest. Look forward to seein the finished shelves
View Jim Jakosh's profile
Jim Jakosh
7332 posts in 1277 days
#2 posted 302 days ago
I’d finish both sides. If you want something quick to dry, shoot it with clear lacquer. You can get 3 coats on it a day, easily….......Jim
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
View Clint Searl's profile
Clint Searl
850 posts in 533 days
#3 posted 302 days ago
As Jim said, lacquer would be best, but if you can’t spray, waterborne poly would be the way to go. No BLO.
-- Clint Searl.............We deserve what we tolerate
Blackie_
#4 posted 302 days ago
Ok so pure Lacquer seems great to me, what about Tung oil I’ve used Lacquer over it before with success but I do think it takes a day for drying. What about the natural oil that is in Cyperss would I need to cure this?
View Greg The Cajun Box Sculptor's profile
3780 posts in 1480 days
#5 posted 302 days ago
I have worked alot with cypress and used numerous finishes over the years. Cypress is a wood with natural oily resins in it…which make it very resistant to decay.
I have found the following results:
Drying time varies considerable depeending if it is new growth cypress, old cypress or sinker cypress.
A polyurethane finish is the most durable but sometimes the first coat will take 3 – 4 days to dry.
Tung Oil …any finish with an oil base will dry very slowly.
Water based finish will also dry quickly and allow numerous coats…. and not leave a lingering smell for days that polyurrethane or lacquer leaves. Does not really bring out the beauty of the woodgrain.
Lacquer… dries extremely fast and you can spray numerous additional coats in a day. I use lacquer on the boxes I build and really like the appearance. Looks especially good if you buff with steel wool.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
View HerbC's profile (online now)
HerbC
779 posts in 1031 days
#6 posted 302 days ago
Randy,
Yes, do finish both (all) sides of the project.
Sounds like you’ve received pretty good advise on finish selection.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Blackie_
#7 posted 302 days ago
Ok thanks all Lacquer it is then.
View bruc101's profile
bruc101
526 posts in 1713 days
#8 posted 302 days ago
Go to Lowes and get you some Deft Lacquer. Says brushing lacquer on the can because of VOC regulators.
It can be brushed or sprayed. Deft is some of the finest lacquer on the market.
Dries fast. When we use it we can usually get three or four coats a day. Sand with fine paper between coats for a more deep looking finish.
Dust the first coat on to raise the grain and let it dry…sand and then keep going. We thin about 10%.
As a matter of fact, we’re getting ready to use the Deft Semi Gloss on a large set of Cherry kitchen cabinets and will put 5 coats lightly sanding between coats. Will be completed in less than 2 days.
We’ve sprayed loads of Deft on Cypress. Deft is very user friendly.
-- Bruce http://plans.testsitem3.info http://www.sawmillgirls.com
View boxcarmarty's profile
boxcarmarty
6508 posts in 532 days
#9 posted 302 days ago
Definitely Both sides. If for no other reason, it will make it easier to dust. I also agree with the lacquer…..
-- My mind is like lighting, one brilliant flash, then its gone.....
Blackie_
#10 posted 302 days ago
Marty I never dust LOL but as I type this and think about it, the shelfs will be for my bandsaw boxs as I’m running out of room to store them which are also my pride and joy so I might make an exception in this case LOL go get me one of those swifter duster thingys hahaha.
