Steel stud for a straight edge?
Forum topic by Lumber2Sawdust posted 300 days ago 1489 views 0 times favorited 18 replies Add to Favorites Watch
View Lumber2Sawdust's profile
Lumber2Sawdust
112 posts in 1035 days
300 days ago
I’m working on a project and I want to use a router to “joint” a straight edge on two 8 foot slabs. In order to accomplish this, I need a decent 8’ straight edge.
I looked at the big box stores and they sell 8 foot levels, which run about $100.
My next thought is a sheet of plywood. I could keep a 12” wide piece of ply for future use as a straight edge, too.
I took a tour around the store and I saw a rack of steel studs. By eye, they look pretty straight. They have a U-shaped profile and are pretty rigid so they won’t flex. The cost $5-6. For the price, and the easy storage, I’m thinking about giving it a shot.
Has anybody else used a steel stud for a straight edge? Do you have any other repurposed items that you use for a straight edge instead?
18 replies so far
View tomd's profile
tomd
1315 posts in 1940 days
#1 posted 300 days ago
No, but why not ?
-- Tom D
View FirehouseWoodworking's profile
568 posts in 1443 days
#2 posted 300 days ago
Aluminum U-channel, steel struts also work.
I also use MDF molding and dimensional trim. If you find a piece that has a damaged edge and the other edge is fine, you can often get it for a big discount because it won’t sell for it’s intended purpose. But all I need is one good edge.
-- Dave; Lansing, Kansas
View Doss's profile
Doss
777 posts in 434 days
#3 posted 300 days ago
I know at the blue big box store that they have a long straight-edged ruler that is $10. I want say it’s 8’ long, but it could be shorter (maybe 7’).
I like the fact that it is easy to clamp down to a surface so I can use it as a cutting guide for the circular saw or router plus get consistent straight lines.
Do those studs have square angles or do they have a slight round to them? If they are even slightly rounded at the corners, it could be difficult to draw straight lines.
-- "Well, at least we can still use it as firewood... maybe." - Doss
Lumber2Sawdust
#4 posted 300 days ago
Thanks for the replies.
Doss, the studs to have slightly rounded corners. If I can establish that the material is straight (draw a line, flip it over and draw a complimentary line to see if they match) then I will be using it more as a guide for a router then for actually drawing accurate lines.
For a $5 investment, I’m going to give it a shot. Worst case, I can return the unused stud and it wouldn’t cost me anything.
View jmos's profile
jmos
637 posts in 539 days
#5 posted 300 days ago
You can look and see if they have an aluminum right angle extrusion; I’m drawing a blank on the proper name, but it’s bent at a 90deg angle, usually with a sharp right angle on the outside. It’s pretty rigid, light, and usually quite straight, I just don’t know if they carry it in 8’ lengths. I saw a Chris Schwarz video where he used a pair of 3’ long pieces as winding sticks; straight, cheap, and won’t fall over.
-- John
View HerbC's profile
HerbC
778 posts in 1029 days
#6 posted 300 days ago
I have used a steel stud for an edge guide many times without any significant problem.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Gshepherd's profile (online now)
Gshepherd
1363 posts in 371 days
#7 posted 300 days ago
I have used that steel they use for hanging garage doors with all the holes in it….. Later if can come in handy for other things as well….
-- What we do in life will Echo through Eternity........
View MrRon's profile
MrRon
1578 posts in 1413 days
#8 posted 299 days ago
Will a steel stud work? It all depends on how straight you need it to be. All the items mentioned, were not designed to be straight edges, although they are reasonably straight, but no guarantee. steel and aluminum shapes you find at big box stores can be mangled by store personnel and end up not-too-straight. I have a Starrett 5 ft straight edge, but it cost $100 +. For woodworking, I use a piece of plywood about 12” wide as a guide for a “Skil” saw. It’s about as good a straight edge you will find.
View sixstring's profile
sixstring
245 posts in 413 days
#9 posted 299 days ago
the term for the garage door hangers is “angle iron” and could be pretty handy in the right situations.
-- JC Garcia, Concord, CA : "It's easier to ask forgiveness than permission..."
View dhazelton's profile
dhazelton
830 posts in 466 days
#10 posted 299 days ago
Angle iron.
View Don W's profile
Don W
9952 posts in 737 days
#11 posted 298 days ago
I use an old bed frame. Its angle steel, good and straight, cost nothing, I can drop it, throw it and it just comes back for more. Its not 8”, but angle can be purchased fairly reasonable.
MrRon
#12 posted 298 days ago
You can find old bed frame angles at a local Goodwill or Salvation Army outlet for 2 or 3 dollars.
View rejo55's profile
rejo55
149 posts in 412 days
#13 posted 298 days ago
I have used aluminum angle many times, mainly because it has a good, sharp corner. “Course, I don’t work to the 10/000 inch, so it does fine for me. My best buddy, (the last of the big-time Alabama rednecks) uses a piece of steel plate-3/4” x 6” x 10 feet. I ain’t quite the man he is.
Have a good’un
Joe
-- rejo55, East Texas If there were no trees, there wouldn't be much wood.
Lumber2Sawdust
#14 posted 297 days ago
So I took the plunge and spent $6 on a steel stud. I “borrowed” an 8 foot box level from the tool department and checked how straight the stud was. I passed on the first one, but the second one I checked was very close over 8 feet.
I set it up my slabs and clamped on the stud. 15 minutes later I had to edges that are nicely jointed.
After clamping the ends of the stud to the slab, I was surprised that there was some lateral flex in the center. It was probably only 1/32 of flex. Close enough for the work that I do. That stud will be stored away in the rafters of my shop for the next time I need a long guide for the router.
Thanks for all of your suggestions.
View Sylvain's profile
Sylvain
465 posts in 669 days
#15 posted 287 days ago
A bit late (coming back from hollyday travel)
look at :
http://americanwoodworker.com/blogs/tips/archive/2008/06/29/8-ftStraightedge-for-4.aspx
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
