Do Knots in Cedar Cause Structural Weakness?
Forum topic by Furnitude posted 302 days ago 732 views 0 times favorited 11 replies Add to Favorites Watch
View Furnitude's profile
Furnitude
244 posts in 1678 days
302 days ago
I’m making a set of Adirondack chairs and this is my first time to really use Western Red Cedar. If you look at the crude drawing, I’ve tried to show the location of a knot in one of the boards I’m going to use for arms. Will a knot in this location cause structural weakness? Thanks for any comments.
-- Mitch, http://furnitude.blogspot.com
11 replies so far
View Ryan Haasen's profile
Ryan Haasen
340 posts in 571 days
#1 posted 302 days ago
Yes, I think it will, especially if it has a hollow spot.
-- Ryan
View Doss's profile
Doss
777 posts in 435 days
#2 posted 302 days ago
Yes. If the knot is that circle and it takes up that much space, it’s going to be a problem. The knots usually fall out of WRC.
If the wood were really thick and the knot pretty shallow, possibly not. But, it looks like, in this case, that it’s going to be an issue if it gets any load applied to it.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View Blackie_'s profile
Blackie_
1666 posts in 683 days
#3 posted 302 days ago
I’m curious if CA wouldn’t solve that problem, I know it would keep the knot from falling out. One other thing you might try is making a western sawdust paste using wood glue and fill in the voids also blending.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
View gfadvm's profile (online now)
gfadvm
6647 posts in 861 days
#4 posted 301 days ago
I learned the hard way that knots at stress points are the weak link and will fail in a load bearing situation. In my tall chairs of recycled Doug Fir, I have learned to avoid putting knots in the legs or seat slats. I’m referring to full thickness knots of significant diameter (3/4-1”).
View Arlin Eastman's profile
Arlin Eastman
1312 posts in 732 days
#5 posted 301 days ago
It will cause a weak point, however, I do know of several guys that have drilled them out and put in epoxy in the hole with some ceder dust.
Arlin
-- It is always the right time, to do the right thing. Lovinghandsmemoryboxs.com
View Bearpie's profile
Bearpie
2475 posts in 1188 days
#6 posted 301 days ago
Yes, definitely it will weaken the area. could you possibly switch the board around and put the knot on the wider part of the board?
-- Erwin, Jacksonville, FL
View MonteCristo's profile
MonteCristo
2061 posts in 359 days
#7 posted 301 days ago
Curious that someone in Tennessee is using Western Red Cedar (WRC) which is native to my neck of the woods. This wood is weak structurally to begin with, which makes it even more important that a knot like the one you show should be avoided.
In case you aren’t familiar with WRC, it is very easy to crush so cutting motises and the like requires really sharp tooling. It is quite rot resistant but that comes at a price – depending on who you talk to it’s dust is toxic to very toxic. Some people out here even get an alergic reaction just handling it, although that is pretty unusual. Old growth WRC is a much better wood than second growth stuff, much deeper color to the heart wood and very stable with fine annual rings. Much more rot resistant too I suspect than second growth.
View bondogaposis's profile
bondogaposis
1254 posts in 522 days
#8 posted 301 days ago
I would be looking for another piece of wood for that.
-- Bondo Gaposis
View rrdesigns's profile
rrdesigns
413 posts in 1356 days
#9 posted 301 days ago
And some ears, legs and a tail and you can use that piece for an elephant. Waste knot want knot.
-- Beth, Oklahoma, Rambling Road Designs
View tomd's profile
tomd
1317 posts in 1941 days
#10 posted 301 days ago
I would be leary of using it.
-- Tom D
View woodtools's profile
woodtools
18 posts in 460 days
#11 posted 301 days ago
A western red cedar knot as you display in the drawing has no structural value. If you were to think about your adirondack chair arm as having a hole in it the size of the knot, you will answer your own question. As with western red cedar, used in outdoor applications, the knot as described will fall out in 8-12 months
Good luckwith what will be a beautiful piece of outdoor furniture.
