Wagner HVLP gun
Forum topic by BentheViking posted 300 days ago 738 views 0 times favorited 11 replies Add to Favorites Watch
View BentheViking's profile
BentheViking
1135 posts in 733 days
300 days ago
Topic tags/keywords: finishing spray gun question
Someone gave me one of these. Instructions say to only use it outside and not to use with latex products. I am about to buy a house and will be renovating the entire thing. Would I be crazy to try and use this tool to paint my walls and ceilings? I can open up a ton of windows to get a good amount of cross ventilation.
If I choose not to use this for this project has anyone used one to spray woodworking projects? What kind of results did you get?
-- It's made of wood. Real sturdy.--Chubbs Peterson
11 replies so far
View Doss's profile
Doss
777 posts in 433 days
#1 posted 300 days ago
Which Wagner is it? Do you have a picture?
I used the Paint Crew one, but it’s an entirely different type of sprayer than the HVLP ones.
-- "Well, at least we can still use it as firewood... maybe." - Doss
825 posts in 662 days
#2 posted 300 days ago
I have that and use it frequently to spray lacquer, waterbornes, and shellac. It’s possible (maybe) to get the projector set to spay latex (these guys have parts for it), but yes, I think it would be crazy to do what you suggest. If you really want to paint the whole house buy on of the airless latex sprayers and use it…sell it later after your done. Or just roll it on….BTW, if the ceilings are textured and you choose to roll them, be sure to prime with an oil based primer first. Latex paints can loosen the crap and then it falls off, or sticks to the roller or does other PITA things.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View Lifesaver2000's profile
Lifesaver2000
463 posts in 1281 days
#3 posted 300 days ago
Wagner makes a few different HVLP units. I have the “Control Spray Plus” which uses a small turbine connected by a 20’ hose to a spray gun. They also make a self-contained HVLP sprayer where the motor is on the back of the gun.
I have the first one, the Control Spray Plus, and have used it for water and solvent based polyurethane. It does fine, although it seemed to do better with the water-based poly. It is pretty easy to clean and gets the job done fast. The last four of my projects that I have on here were finished with it.
It comes with a viscosity cup, so it might be possible to thin latex down to where it would work, but I haven’t tried it.
BentheViking
#4 posted 300 days ago
This is it here. After reading the Amazon reviews I decided that maybe it can work to spray latex, maybe not, but that regardless its just too slow to do a house like I would attempt. I was hoping for a quick and easy alternative. The only time I’ve used HVLP was in a custom millshop with a few grand spraying rig and an 80 gallon 220v compressor with separators and regulators throughout the line. Not quite apples and apples. Maybe more like apples and applejacks.
Fred, thanks for the tip, but we are actually starting by water blasting and scraping all the texture off of the ceiling first (my uncle is a sheetrock contractor and is lending a hand).
View Sawkerf's profile
Sawkerf
1776 posts in 1237 days
#5 posted 300 days ago
Are you sure it’s an HVLP? I used to have a Wagner airless that was pretty worthless – and really bad with latex.
There should be a model/serial number on it somewhere. The Wagner website should have the manuals.
View Doss's profile
Doss
#6 posted 300 days ago
Ben, I know this doesn’t help much since you already have the gun, but I used this one:
http://www.amazon.com/Wagner-Power-Products-515000-Sprayer/dp/B00009YUHK/ref=sr_1_9?s=hi&ie=UTF8&qid=1343241623&sr=1-9&keywords=wagner+crew
That thing can lay down some paint fast.
The problem you’ll run into with a sprayer like the one you have (besides the tip) is how often you’ll need to refill it on any large job. I would consider painting a room or furniture with it, but not a house exterior.
BentheViking
#7 posted 300 days ago
kerf, I have the manual and it as well as the box says HVLP all over it
Doss I am painting the interior, not the exterior, so your product may work, I just don’t know if its heavy duty enough or worth the cost to buy it to paint an entire interior.
Lifesaver2000
#8 posted 300 days ago
If you aren’t locked in to the idea of spraying, there is another option. About 12 years ago I did an addition to my house, and at the time I purchased a Wagner Power Roller. It ran on batteries, and the reservoir held almost a gallon of paint. I used it first to apply a full five gallon bucket of primer to the walls and ceilings throughout the addition, then to paint the ceilings, and finally to paint the main room of the addition. For smaller areas like a bathroom it was easier to just use a conventional roller and pan.
The power roller makes fast work of large areas. I went through that five gallons of primer in no time, compared to a roller and pan. Once you get the hang of it you can paint as fast as you can roll, and get a nice heavy, even coat. The paint I used was suppose to dry four hours between coats. During that time, I simply dropped the whole thing into a garbage sack and tied it up to keep out the air instead of having to clean it between coats of the same paint.
The worst drawback of the thing is the cleanup. That is why it is only worth using it for large areas.
As far as your HVLP gun, that is not the unit I have but the spraying part looks similar. I really like mine for what I use it for, so hopefully yours will do well on any woodworking projects you have later on.
View exelectrician's profile
exelectrician
1004 posts in 596 days
#9 posted 300 days ago
I use a Capspray 9100 four stage turbine, I also mix Flowtrol 20% with house paint PVA water base (see my project cabinet)
The results were fairly good but labour intensive with all the masking. Careful brushing is almost the same in my opinion.
-- Love thy neighbour as thyself
BentheViking
#10 posted 300 days ago
I think my wife actually picked up one of the power rollers at a yard sale for a few bucks. I was a bit skeptical about it being more of a gadget than a tool, and since I’ve had experience spraying I felt more comfortable doing that. After your recommendation I’d better go give the roller manual a once over and hopefully it will do us well. We are only doing a few colors throughout the house so hopefully we can bang it out without too much cleaning.
View Doss's profile
Doss
#11 posted 300 days ago
I realize you’re painting the interior, but that is little info for me to know how much you’re painting? 1 wall? 15 rooms? I should have clarified further, if you are are spraying a large project such as the exterior of a house or if you are painting multiple rooms the same color in a 1500+ sq ft house, I’d use the Crew one I linked above. The clean up time on that system is a little lengthy, but the time it takes to get coverage is almost nothing. You can spray at any angle and can get multiple tips to fit your application. It can also accept a roller attachment.
If you are painting 1 room or doing a lot of color changes on small projects, your system will work fine. I’m not sure how it’s going to work on ceilings though. In fact, the reviews on Amazon say it doesn’t really work on horizontal surfaces which I’m guessing is an issue of the feed. Others on there say that latex paint has to be thinned very heavily.
Just some additional info for you.
