Deep Beautiful 14 Degree Dovetails with a PC Jig? Yep.
Forum topic by pintodeluxe posted 07-25-2012 04:16 AM 5297 views 11 times favorited 11 replies Add to Favorites Watch
View pintodeluxe's profile
pintodeluxe
5569 posts in 2722 days
07-25-2012 04:16 AM
Topic tags/keywords: dovetail dovetails dove tail porter cable porter cable rockler router jig 4210 4212 4216 half blind half-blind halfblind
I have long wanted to get deeper dovetails and a 14 degree angle with my PC 4210 jig. The bit that comes in the kit is 7 degrees, with a 3/8” depth of cut. The standard dovetails have such a shallow angle they almost look like box joints.
After consulting the manual, I learned that when cutting half blind dovetails there are several other bits that will work (Through dovetails are limited to 7 degrees with this jig).
I ordered a Rockler dovetail bit 5/8” wide, with a 5/8” depth of cut, and a 14 degree angle. I set the depth of cut slightly less than 5/8” (measured from the router bushing to the tip of the cutter) and it worked great.
The pictures show the 5/8” deep dovetails next to the 3/8” deep stock dovetails.
I prefer the deeper sockets because they feel stronger, and really look like dovetails.
11 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2486 days
#1 posted 07-25-2012 04:33 AM
Thanks for the update. :)
The 14 degree dovetails indeed look better than the 7 degree ones. A good trick to add to the arsenal.
View jdmaher's profile
jdmaher
418 posts in 2488 days
#2 posted 07-25-2012 12:49 PM
I like the look.
Did you use the standard bushing?
3/4” Front and 1/2” sides?
-- Jim Maher, Illinois
pintodeluxe
#3 posted 07-25-2012 04:31 PM
Jim,
Yes I used the standard PC bushing. In this case I used 3/4” fronts and 1/2” sides, hovever other thicknesses will work too.
The PC advanced manual makes it seem like you need to use two bits and a two-pass method to achieve this look. I should mention that with this bit… it is a one bit, one-pass method.
View Bill White's profile
Bill White
4862 posts in 3869 days
#4 posted 07-25-2012 04:34 PM
Now this is what Jocks is all about. Thanks for the tip.
Bill
-- bill@magraphics.us
View Bertha's profile
Bertha
13508 posts in 2602 days
#5 posted 07-25-2012 04:53 PM
This is really good to know, as I put mine on the shelf for the reason you mentioned. Thanks!
jdmaher
#6 posted 07-25-2012 07:24 PM
Thanks, Willie.
Better looking tails, and still a single pass, huh?
I’m gonna have to give these a try. The 1/2” shank version (Item # 91089) is only $17.99 at Rockler. Very cool!
pintodeluxe
#7 posted 01-15-2013 08:47 PM
I just completed 12 drawers using the 14 degree bit, and was really impressed with the results. I am using 3/4” oak for the fronts, and 3/4” poplar for the sides. I can’t believe how much stronger these joints feel with the bigger dovetails.
The setup is so easy on the Porter Cable 4210 / 4212 jig.
View RogerInColorado's profile
RogerInColorado
321 posts in 1863 days
#8 posted 01-23-2013 12:01 AM
This is Super!
View Socceref's profile
Socceref
22 posts in 1893 days
#9 posted 03-12-2013 08:08 PM
Thanks for the information nice to know.So you can use the 7 or the 14 degree bits with the same template?
Paul
View AandCstyle's profile
AandCstyle
2979 posts in 2166 days
#10 posted 03-13-2013 12:37 AM
Willie, these are very nice looking DTs. I can hardly wait to see the finished product.
-- Art
pintodeluxe
#11 posted 03-13-2013 06:45 AM
Paul,
You can use both 7 and 14 degree bits for the half blind template.
The through dovetail template is limited to a 7 degree bit.
Good luck!
