| Forum topic by DanoP | posted 299 days ago | 579 views | 0 times favorited | 5 replies | ![]() |
299 days ago |
OK… Novice here – only been doing small stuff (boxes, etc) for about a year and would like the opinions of some of my seniors here on LJ. What have you found to be the best and/or easiest way to finish porous woods to get that glass like smooth finish and avoid the “pitty” look shown here on my latest project (http://lumberjocks.com/projects/69104)? I appreciate your help friends. -- We've got enough youth. Let's search for a fountain of smart. |
5 replies so far
#1 posted 299 days ago |
It takes a lot of coatsof finish and a lot of rubbing between coats. If you use a paste filler before the finish that will fill a lot of the pores. I just put a coat of finish on then sand with 320grit dry. The next coat I go to 400wet or dry depending what I feel like. Then next few coats I will sand with 600 grit wet. When the finish is looking pretty deep and smooth I will switch to 1200 grit wet. After the last coat I use a 0000steel wool and soapy water to get rid af any dust then polishing compound to get the shine back. The number of coats you need will vary with the wood and the type of finish. -- Bruce |
#2 posted 298 days ago |
Trying to fill pores with finish is a long arduous process. TimberMate grain filler is very easy to use and quickly solves the pore problem. It comes in matches for many types of wood and I use it a LOT! Woodcraft is the only local source for me. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#3 posted 297 days ago |
Agreed, use a grain filler that is similar to or slightly darker than the wood you are filling. -- -- Rick M. |
#4 posted 297 days ago |
How does the grain filler affect figured woods who’s sheen changes in the light? The sample shown and here http://lumberjocks.com/projects/69104 is African mahagony that changes color like a tiger’s eye stone in the light, will the grain filler affect that sheen? -- We've got enough youth. Let's search for a fountain of smart. |
#5 posted 297 days ago |
DanoP- My best advice would be to try the TimberMate and your finish on a piece of scrap and make your decision based on that. TM is very inexpensive so you can afford to test it. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1525 |
3543 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6151 |
