How much sanding is enough?
Forum topic by rut posted 07-24-2012 12:24 PM 1175 views 0 times favorited 8 replies Add to Favorites Watch
View rut's profile
rut
62 posts in 2378 days
07-24-2012 12:24 PM
So I’m progressing on my kitchen cabinet project to the point I have all the carcasses built, the face frames put together, and just finished routing my stiles and rails for the raised panels.
I now notice that some of the stiles/rails are not completely smooth along the routed areas. There is some kinda rough feeling grain on the small curved section. So I’m thinking I need to sand this down to get it perfectly smooth for a decent paint job. Then I look at how many I have to do and I’m thinking this is going to take a week to sand these by hand.
I can’t help but think that most shops don’t do this or they have a specialized sander to do it. This is soft maple wood and I used new router bits (from Sommerfeld tools) and made 3 passes (from shallow to full cut).
So is this normal to still have to sand this much or will the primer help cover this and make it smooth and I should fuss too much on it? Is there a more expediate method to sand these sections?
Thanks,
Rut
8 replies so far
View dhazelton's profile
dhazelton
2767 posts in 2292 days
#1 posted 07-24-2012 12:35 PM
If it’s just a bit of fuzz and sandpaper doesn’t do much now, put a coat of finish on it to stiffen the grain, THEN sand it. As far as a mechanical sander, you’d probably have to look for the correct profile head for an oscillating tool (pricey?), but I would probably just hand sand with some kind of fine sanding sponge.
404 - Not Found
2544 posts in 2965 days
#2 posted 07-24-2012 12:41 PM
It’s not that much of a chore really, use an abrasive with a light weight backing paper to follow the contour without rounding off the quirk. +1 on applying a coat of finish if the rough fibres are woolly.
View AandCstyle's profile
AandCstyle
3051 posts in 2253 days
#3 posted 07-24-2012 11:34 PM
1. Put wax paper or plastic wrap on the profile. 2. Put Bondo on the paper or plastic. 3. Put a stick into the Bondo and let it harden. 4. Replace the paper or plastic with light weight sand paper and you will have a custom shaped sanding block. Try this on a bit of scrap first to get familiar with the process.
-- Art
View Raymond Thomas's profile
Raymond Thomas
189 posts in 2214 days
#4 posted 07-25-2012 12:19 AM
+1 on what Art said – it works like a charm.
-- Raymond, Charlotte, NC -------- Demonstrate the difference!
View Doss's profile
Doss
779 posts in 2260 days
#5 posted 07-25-2012 04:27 PM
+1 Art. Good thinking.
Also, just a piece of advice, don’t rush through things. If you’re taking the time to build cabinets, realize that all those finishing steps will probably take a good deal of time but the result will be great.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View StumpyNubs's profile
StumpyNubs
7590 posts in 2796 days
#6 posted 07-25-2012 04:29 PM
As a general rule, if you hit bench, you’ve gone too far…
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View Gshepherd's profile
Gshepherd
1727 posts in 2197 days
#7 posted 07-25-2012 10:28 PM
Festool makes a sanding kit which you could try for custom profiles like this. Pricey as expected.
Also I have used sticky back sandpaper I would put on the profile and had some big chunks of starfoam, rub the starfoam on the sandpaper and when you hit your desired profile, take some glue and brush on the starfoam, titebond glue dries and it will stiffen up a bit and put some sandpaper on it. Won’t last forever but should get the job done.
The bondo trick works well also but I would put a piece of wood for a makeshift handle of sorts and let it all set up. when done looks like some old time iron…..
-- What we do in life will Echo through Eternity........
View Bearpie's profile
Bearpie
2601 posts in 3013 days
#8 posted 07-26-2012 03:03 AM
If you want perfection, you have to do what is necessary!
-- Erwin, Jacksonville, FL
