pals system won't let me set my blade to 45 degrees
Forum topic by turnkey47 posted 07-23-2012 07:22 PM 1043 views 0 times favorited 7 replies Add to Favorites Watch
View turnkey47's profile
turnkey47
271 posts in 2685 days
07-23-2012 07:22 PM
installed the pals system on my powermatic 64a tablesaw a while back…everything went very smooth and got the blade lined up easily…went to set my blade to 45degrees last week and it only allowed me to go to 40 degrees…the reason being is that the rod tilting the blade is hitting on the stud that was installed for the pals…does anyone know how to adjust this to let the blade be set at 45 degrees…i emailed jerry cole last week with this problem but have yet to get a response from him
7 replies so far
View dakremer's profile
dakremer
2672 posts in 3085 days
#1 posted 07-23-2012 07:34 PM
I had the same problem, I had to use the original bolt on the side of tilt to keep it out of the way – the bolt that came with the PALs was too long. Hopefully it’s still as accurate and secure. So far so good
-- Hey you dang woodchucks, quit chucking my wood!!!!
turnkey47
#2 posted 07-23-2012 09:59 PM
thats what i was thinking of doing but first wanted to hear from jerry at a line industries….did u have a problem getting the stud out with the loctite on it????? thanks again for the reply!!!!!!!
View DIYaholic's profile
DIYaholic
19618 posts in 2669 days
#3 posted 07-23-2012 10:42 PM
I have a C’man TS. It has 3 bolts holding the trunnion. Jerry said to align the saw, tighten 2 of the 3 bolts, then remove the PALS from the “offfending” location & install the original bolt. I haven’t attempted it yet as I was waiting for my machined pulleys to arrive & do everything at once.
Hope this helps.
turnkey47
#4 posted 07-23-2012 11:49 PM
i guess thats what i will have to do…my only concern is the loctite holding the stud,i don’t want to brake off the the stud…thanks for your reply
View crashn's profile
crashn
528 posts in 2459 days
#5 posted 07-24-2012 12:27 AM
to loosen locktite, heat up the stud, the locktite will break loose that way. moderate heat with a torch will work.
-- Crashn - the only thing I make more of than sawdust is mistakes
turnkey47
#6 posted 07-24-2012 09:27 AM
thanks for the info crashn i will try that
crashn
#7 posted 07-24-2012 10:44 AM
no problem
