Planer Sled for Flattening Boards
Forum topic by dsbwoodcraft posted 07-23-2012 02:06 AM 2539 views 0 times favorited 12 replies Add to Favorites Watch
View dsbwoodcraft's profile
dsbwoodcraft
3 posts in 2163 days
07-23-2012 02:06 AM
Hello Lumberjocks—this is my first post.
I have some slightly bowed maple and walnut boards that I need to flatten before I resaw them. I know that if I run them through as they are, I will end up with smoother bowed boards. I have read somewhere that you can make some kind of a fixture that enables you to send the boards through the planar and get them flat. I just cant remember how it is done.
I have thought of screwing or stapling the sides of the boards to a pair of runners that I know are flat and running that through the planar but I’d like to check with you all first to see if someone had a better idea. Has anyone out there done this before? If so, I would greatly appreciate you sharing your experience- especially if you have pictures. Thanks!
12 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2719 days
#1 posted 07-23-2012 02:50 AM
I put thin wedges under my problem board where there are gaps after sticking it to a known flat board, chalk the surface, and run rthrough the planer until the entire surface is free of chalk (or Pencil) marks. Then take it of the flat board, flip it over , and plane to thickness. If your board has very much cup, twist, or warp you can end up with very thin stock!
dsbwoodcraft
#2 posted 07-24-2012 02:13 AM
Sounds easy enough. Do you just use a little carpet tape to hold the board onto the flat stock? I will give it a try. Thanks.
gfadvm
#3 posted 07-24-2012 02:47 AM
I use double faced tape for smaller boards and screwed on cleats for bigger ones. Just make sure your cleats/screws are well below the planer blades!
View derosa's profile
derosa
1577 posts in 2864 days
#4 posted 07-24-2012 02:51 AM
Although there is a longer wait time I just glued shims to the bottom of my board due to length. I can use my bench to test out a 6’ board but don’t have flat plywood to build that large a sled on so I grabbed a bunch of thin cut offs out of the garbage to use as shims and when I had just the right shims I glued them in place. Mine was twisted so made sure to shim both ends so that one end wouldn’t be made to thin by only shimming the one end.
-- --Rev. Russ in NY-- A posse ad esse
View D_Allen's profile
D_Allen
495 posts in 2813 days
#5 posted 08-04-2012 12:01 AM
I use a melamine shelf and hot melt glue.
The glue keeps the shims in place and set up fast. It also comes off the boards easy.
It just takes a little glue on each and I use some glue on the trailing end to help keep it from slipping.
-- Website is finally up and running....www.woodandwrite.com
View dnick's profile
dnick
986 posts in 2411 days
#6 posted 08-04-2012 03:43 AM
If you can get hold of Wood magazine Sept. 2012, #213, there’s a good article & picture. I am going to try it with a twisted piece of maple I have.
-- dnick, North Hollywood, Ca.
View Tokolosi's profile
Tokolosi
678 posts in 2384 days
#7 posted 08-04-2012 05:39 AM
I knew there was a purpose for Melamine boards! Great tip.
-- “There is nothing like looking, if you want to find something. You certainly usually find something, if you look, but it is not always quite the something you were after.” ~ JRR Tolkien
View pintodeluxe's profile
pintodeluxe
5706 posts in 2842 days
#8 posted 08-04-2012 06:25 AM
If you don’t have a jointer, those techniques mentioned will work. Don’t expect perfection.
View volfan's profile
volfan
6 posts in 2150 days
#9 posted 08-07-2012 03:59 PM
The January 2005 issue of Fine Woodworking Magazine has plans for a planer sled that works great. I made a 4 ft. and 8 ft. version. I use them often.
-- JLD, Tennessee
View Richforever's profile
Richforever
757 posts in 3749 days
#10 posted 08-07-2012 06:30 PM
http://www.finewoodworking.com/SkillsAndTechniques/SkillsAndTechniquesArticle.aspx?id=5245
I built the Fine Woodworking sled in the video listed here, and it works great.
(not sure how to make the address a direct link)
-- Rich, Seattle, WA
View Gene Howe's profile (online now)
Gene Howe
10548 posts in 3457 days
#11 posted 08-07-2012 07:26 PM
As did Rich, I built that sled, too. It does work great.
View Gshepherd's profile
Gshepherd
1727 posts in 2230 days
#12 posted 08-11-2012 10:11 AM
Try glueing straight and flat runners on both sides of the board…... make them 6 or so inches longer than the board and it will help with any planer snipe you may have. Remember also a good drum sander will do the same. When your done just saw off the runners. Hope this makes scense…. I normally use poplar for the runners I call them cause it is cheap.
-- What we do in life will Echo through Eternity........
