I need Some Hand Planer Advice
« back to Hand Tools forum
Forum topic by MT_Stringer posted 07-23-2012 02:04 AM 1300 views 0 times favorited 6 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3136 posts in 3107 days
07-23-2012 02:04 AM
I know there are a lot of you that love your hand planers and restore the old ones. I have a small palm sized one that I have only used a few times. I would like to buy a larger one but I just don’t know where to start.
So, if you throw out the high end ones and the cheap ones, where does that leave me for a first purchase?
Your advice appreciated.
Thanks.
Mike
Smitty_Cabinetshop
14977 posts in 2495 days
#1 posted 07-23-2012 02:20 AM
Mike, good question on Hand Planes!
I’m guessing you like what you’re able to do with your block plane, even though you many not use it much. Really big question that will help us answer the question ‘which larger one.’ Unless the question is really, ‘what brand should I be looking at?’
For the former, a good plane for an otherwise electric shop person is a smoother. When you pull stock from the planer or jointer, for example, the smoother (#4 in the Stanley world) will give it a final feel that cannot be beat. It takes some work to get it tuned for the best results. For the latter, a pre-war Stanley is affordable and a top-notch tool. Clues are rosewood handle and knob, Stanley written on the lever cap (or nothing on the cap) without color in the background, and a lever cap that has a screw hole the shape of a keyhole vs. ‘kidney shaped.’ Get those things, and you have a plane that has good lateral adustment, a solid frog and a frog adjustment screw. With those good ‘bones’ you’ll be able to tune it, per very good odds, to take great shavings.
Let us know if this hits close to the mark! Good luck!
View ShaneA's profile
ShaneA
6882 posts in 2475 days
#2 posted 07-23-2012 02:20 AM
You have many options, at many price points. For new, maybe a Woodriver #5. They only require minimal work out of the box, about $150 I think. Vintage, unrestored is the cheapest way. But you will have to put time into it. Some like to restore, others…not so much. The cost, maybe $20-40 for a vintage Stanley Bailey. Best option for cost, time, and function might be vintage, but restored. Ready to go, quality out of the box. Cost $50-60. I know Don W routinely offers fine restored planes. In any case you will need a quality sharpening process.
MT_Stringer
#3 posted 07-23-2012 02:54 AM
Thanks for the advice. a smoother might be my best choice. this week, I plan to start building my niece’s graduation present – a teacher’s podium. She recently graduated from Texas A&M and I vowed to build her something can use for a long time to come. Maple hard wood and plywood is my choice.
So, after I get the wood planed, it might be good to have a hand plane to smooth it.
I would rather buy new. I guess I need to make a trip to Woodcraft.
View Dan Lyke's profile
Dan Lyke
1519 posts in 4001 days
#4 posted 07-23-2012 04:07 AM
I had a basic Stanley block plane that my grandfather gave my dad, but it took someone on Craigslist selling me a slightly better one that they’d also taken the time time true and tune to make me fall in love with the block plane.
I think the main difference between the planes isn’t the castings or the design, it’s what’s done with those castings to clean them up and turn them into a well tuned, sharp, plane that does what you want it to do.
Yes, my next plane (and, for that matter, chisel) will probably be a Lie Nielsen, but that’ll be partially for the core of what the product is, and mostly because they’ll have taken the time to take that from a rough forging or casting to turn it into a real thing that I’d like to use, so that when I get it I’ll know what it can accomplish.
bandit571
18949 posts in 2560 days
#5 posted 07-23-2012 04:16 AM
My smooth planes
and my block planes. Mostly refurbished by me. Even have a few bigger planes..
and a jack or two
Isn’t that hard to do, just takes a little elbow grease…...
View Mosquito's profile
Mosquito
9193 posts in 2169 days
#6 posted 07-23-2012 04:30 AM
Shane brings up a good point…In any case you will need a quality sharpening process.
The planes might not be too expensive if you buy vintage and restore (my path), but I’ve spent a fair chunk of change on sharpening stones to keep the planes happy. You can have the best plane in the world, but it won’t do anything worthwhile if it isn’t sharp…
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
