Glue the panels or leave loose?
Forum topic by sphayden posted 07-23-2012 02:03 AM 3999 views 0 times favorited 14 replies Add to Favorites Watch
View sphayden's profile
sphayden
38 posts in 2314 days
07-23-2012 02:03 AM
Topic tags/keywords: frame and panel
I’m making a bed headboard, it’s a frame-and-panel design. There are 1” mortise and tenon joints in each corner and a center stile with a tenon that fits into the groove for the panels. Should I glue the panels also, or just glue the joints? Will it be strong enough if I just glue the joints?
14 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3094 days
#1 posted 07-23-2012 02:19 AM
In frame and panel construction, the panels should be able to “float” to minimize problems due to expansion and contraction.
In my personal experience, solid wood panels (i.e. raised) should definitely float, The majority of my flat panel doors are made with 1/4” (5.2mm if you insist) and I don’t concern myself too much about them. Plywood won’t expand and contract as much as solid wood.
When I glue up any frame and panel, I use a dab of glue in the center of the top and bottom rails to keep the panel from shifting if/as the stiles expand and contract.
If your panels fit loosley in the frames, use some space balls so they won’t rattle. Rattling is bad enough in a door, but would be truly annoying in a bed headboard.
View Grandpa's profile
Grandpa
3259 posts in 2701 days
#2 posted 07-23-2012 02:22 AM
The joinst should be strong enough. If you glue the panels they normally swell with humidity changes and push the joints apart. Leave the panels loose. Make some little silicone caulk drops about the size of BB’s. After they cure insert them into the grooves then install the panels. These will stop the rattle but they will compress if needed. Use then on at least 2 adjacent sides of the panels. Good luck with the bed. Post some pics when finished.
View pintodeluxe's profile
pintodeluxe
5705 posts in 2839 days
#3 posted 07-23-2012 02:25 AM
If you glue a panel at all, just glue a dab in the center of the panel. Do this at the top and at the bottom. This will keep the panel centered, and let the sides expand and contract. If you glue a solid wood panel in a frame, it will crack.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3208 days
#4 posted 07-23-2012 02:29 AM
Same as above, don’t glue them, make sure they are slightly undersized and use silicone spacers to keep the panels from rattling. I’ve also seen panels with a drop of glue in the center of the panel top and bottom assuming the grain in the panel runs up and down, it allows the panel to expand but the panel stays centered.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
View Arlin Eastman's profile
Arlin Eastman
4232 posts in 2587 days
#5 posted 07-23-2012 02:31 AM
One thing you can do to not ever have aloose panel is to use the little rubber balls or some of the very thin strips of rubber in the all around the panel.
Arlin
-- It is always the right time, to do the right thing.
View kizerpea's profile
kizerpea
774 posts in 2393 days
#6 posted 07-23-2012 11:54 AM
dont glue the panels..if u do .you will be in the den watching tv, an u will here a gun shot pow.thats the head board expanding.
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View MonteCristo's profile
MonteCristo
2099 posts in 2214 days
#7 posted 07-23-2012 04:21 PM
Yup, the whole purpose of frame and panel is to allow for movement with humidity changes. Gluing the panels would go against the whole thinking that makes frame and panel a successful design.
View Nicky's profile
Nicky
695 posts in 4117 days
#8 posted 07-23-2012 04:29 PM
I’ve not seen this mention but a few dabs of silicone calking, in each side of the panel has worked well for me.
-- Nicky
View rance's profile
rance
4258 posts in 3186 days
#9 posted 07-23-2012 05:10 PM
Plywood panels: Glue them
Solid wood panels: Let em float
View BigYin's profile
BigYin
418 posts in 2442 days
#10 posted 07-23-2012 05:18 PM
I like 3/8 self adhesive foam strips to stop rattles. (some of the double glazing industry uses it)
-- ... Never Apologise For Being Right ...
4999 posts in 2519 days
#11 posted 07-23-2012 06:26 PM
Quote rance:”Plywood panels: Glue them
Solid wood panels: Let em float”
That’s the practice I’ve always followed…works well.
View MrRon's profile
MrRon
4795 posts in 3269 days
#12 posted 07-23-2012 11:18 PM
If the joints are correctly made, plywood panels shouldn’t need to be glued. They should be treated the same as a solid wood panel; float.
sphayden
#13 posted 07-24-2012 12:34 AM
Wow, thanks everybody for the input. I’m using 1/2” oak plywood for the panels, the good stuff from the plywood supplier (only three layers total). I’m going to go with the majority opinion and not glue them. That is what I would have to do if I had solid panels. Plus, I want to prove to myself how strong those mortise and tenon joints are. I will put the silicone beads in the grooves. Great idea.
View Dallas's profile
Dallas
3599 posts in 2513 days
#14 posted 07-24-2012 12:41 AM
Umm…. 3 layers in a half inch? I have luaun that has more layers than that.
I would expect 5 layers minimum and maybe 7.
