How Many Machines On One Circuit?
Forum topic by javaboy posted 332 days ago 870 views 1 time favorited 13 replies Add to Favorites Watch
View javaboy's profile
javaboy
102 posts in 332 days
332 days ago
Topic tags/keywords: 220v circuits 220v power electric motor amperage ratings question tablesaw
My shop has one 220V 30 amp circuit (yes, it also has a bunch of 110V circuits, but my question is about the 220V circuit).
The only thin connected to the 220V circuit at this time is a Grizzly DC. The motor on that is rated at 18 amps.
I am thinking about buying the Grizzly G0690 TS—its motor is rated at 12 amps.
Can I run both machines on the same circuit? I seem to remember reading somewhere that woodworking machine motors are typically rated on starting amperage only, so I am thinking if I start one machine, and then the other I should be OK. What do you think—can it be done, or will I be better off installing another 220V circuit?
Thanks for any advice!
Karl
-- Sow justice, reap peace
13 replies so far
View Arlin Eastman's profile
Arlin Eastman
1321 posts in 759 days
#1 posted 332 days ago
Java
It is not the machines but the AMPs that each machine draws. In your owners manual and on the ID plate it will tell you the amps of the machine.
So if you have a tablesaw drawing 20 amps you have 10 amps let to use before the breaker trips which is not good to do.
But to your question on both of your machines on at the same time is Yes just as long as you do not start them both at the same time
I hope other chime in to add more
Arlin
-- It is always the right time, to do the right thing. Lovinghandsmemoryboxs.com
View Dan Lyke's profile
Dan Lyke
1372 posts in 2323 days
#2 posted 332 days ago
There are code issues, I’m too burned at the end of the weekend to figure out the details, but I believe that code says you run one 220v circuit to one outlet.
However… from a practical standpoint the question is: What are you going to use simultaneously. If you’re one person in the shop, if the dust collector and the table saw are pulling 18+12 amps at the same time (presumably you’d want to use the dust collector and the table saw at the same time), that’s 30 amps. On a 30A circuit. Maybe those specs are for startup, and the circuit breaker will let you get away with it if you start them at different times. Maybe that’s actual running load, in which case the circuit breaker would be right in shutting you down.
Me? I’d put ‘em on different circuits (almost 4k watts for a dust collector? I hope that sucker is sucking your shop inside out), but maybe you can get away with it…
View Cole Tallerman's profile
Cole Tallerman
381 posts in 383 days
#3 posted 332 days ago
If you turn them on a couple seconds apart they should be fine. My table saw pulls 15 amps when starting but only 12 under a HEAVY load. Also keep in mind that there is a small loss in amps along the cable. Not a large amount but if your right on the full load line it may play a factor. Turning them on at different times tho should work fine.
View MonteCristo's profile
MonteCristo
2066 posts in 386 days
#4 posted 332 days ago
Here in Canada the sustained load (ie when working) on an electrical circuit is only allowed to be 80% of the circuit’s capacity. In your case that would be 24 Amps. As Arlin points out, you can often run two or more machines on a circuit as long as you don’t start them at the same time (motors draw hard on startup). Also, if one machine is just idling (ie not under load) it will draw less and it may be fine to leave it running while you use (one of) the other machine(s). I have two table saws on the same 220V circuit and do this sometimes. I couldn’t have them both working at the same time but I can work one and idle the other which is occasionally handy.
If you are not sure of the actual running AMP draws it is risky to push it as, although you may not pop the breaker you may be over the 80% and that will heat up your wiring – not a good idea.
If you know anyone or can rent a clamp meter you can use it to check the actual AMP draws of your equipment.
In my experience ww motors are rated using the actual AMPS under load, not on start up, although when you hear the term “maximum developed”, which is often used with regards to HP, that is a startup value and is of little use – more of a marketing gimmick to make the thing sound powerful.
View MJCD's profile
MJCD
349 posts in 569 days
#5 posted 332 days ago
The other issue is the wiring, itself. The breaker may be labeled for 30 amps, but you need to have electrical wire leading to the equipment which can handle 30 amps. Generally, a 30 amp draw requires a 10 gauge wire – this would apply only if you have the DC and the TS on the same wire run; that is, a portion of the wiring is feeding both pieces of equipment. I say this, as it is unlikely you would have two leads coming from the 30 amp breaker. 10 gauge is uncommon within non-commercial environments.
I’ve had electricians disagree with me on this; though, all of the publish information, and how I was taught by my electrician Father, say 30 amps requires 10 gauge.
MJCD
-- Lead By Example; Make a Difference
javaboy
#6 posted 332 days ago
Thanks for the input, guys! Sounds like it’s worth giving it a try and seeing what happens. If the CB starts popping I’ll have to bite the bullet and install another circuit.
Monte Cristo—You’ve given me a lot to think about. Could the wires actually develop enough heat to be dangerous without popping the circuit breaker?
MJCD—I am pretty sure the wiring is 10 gauge.
Cheers!
Karl
MonteCristo
#7 posted 331 days ago
javaboy : About the heat thing, I am not sure but I think so, especially if you are running over that 80% I was talking about because the breaker won’t pop until you hit its full (100%) rating (in your case 30 AMP). Things would be even more acute if the breaker is too large an AMP capacity for the actual wiring – I would make darn sure that this is not the case.
I’ve done a few renos over the years and it’s intertesting to see how the sheathing on old wiring has gotten brittle. I am pretty sure some of that it due to it being heated up from time to time.
As I understand it, most house fires are caused by this sort of issue, often skiny extension cords that heat up and the breaker doesn’t pop because the breaker and internal wiring are capable of much higher AMPS.
It’s safer to be cautious and, in the long run, likely cheaper too. You are paying good money on your electric bill to create that heat !
View Grandpa's profile
Grandpa
2399 posts in 873 days
#8 posted 331 days ago
I think you will be pushing it to the limit with the set up you are looking at. I would install a second circuit. Once in a while we all do something that isn’t too smart and I have done most of those things. I got a heavy extension cord hot enough to melt the plug and it didn’t trip the breaker. The wiring in the wall was near the point of a fire. Not a good thing. Install the circuit and sleep better.
View cutworm's profile
cutworm
698 posts in 991 days
#9 posted 331 days ago
The ampacity of #10 awg Romex is 30 amps and that’s continuous. Distance from the breaker is also a factor because of voltage drop. If it is over 50’ or so you will lose horsepower. It’s been a while but I believe the code states that any single device can’t exceed 80% of the breaker rating. I don’t see a situation when you would run both for more than 3 hours so heat shouldn’t be a problem. Wire length may be a problem though and that would hurt the performance of your saw.
-- "Actions speak louder than words but not nearly as often." - Mark Twain
javaboy
#10 posted 331 days ago
cutworm : Actually, I rarely ever run the TS for more than barely a minute at a time—max. Typically I turn the machine on, push a board through it, then shut it off. Then I go around to the out feed side and retrieve the wood. Then I walk back around and get ready for my next cut. Slow and inefficient I may be, but I take that whole “never reach over the blade” thing very seriously. The DC will usually run for longer periods because I am not constantly turning it on and shutting it off like the TS. The only way both those machines would be running for 3 hours is if I dropped dead in the shop.
That said, I will sleep better knowing I’m not pushing the electric system into possibly dangerous territory, so I will be putting in another 220V circuit.
Thanks everyone who replied—I greatly appreciate all the advice!
Karl
View MrRon's profile
MrRon
1635 posts in 1441 days
#11 posted 327 days ago
I would abide by the codes and rules that were put in place. They are there for your safety. if you follow them, everything will work like it’s supposed to. Of course if everyone did this, there wouldn’t be a need for this forum. I seem to recall that code requires all 220V appliances to be on separate circuits. Sounds like smart choice to me.
View dhazelton's profile
dhazelton
849 posts in 494 days
#12 posted 327 days ago
I was staying at a friends house during the heat wave we had in the Northeast last week. He has two ceiling fans running off a switch and in the middle of the night I smelled something acrid. I got up to turn on the light and saw the ceiling fan switch glowing cherry red. I woke him up panicked and he shut down the circuit. I pulled out the still-hot switch—it said it was rated for the amperage of one fan only. FOLLOW CODE! The electrician who installed this switch didn’t and it could have led to a fire.
View Sawkerf's profile
Sawkerf
1730 posts in 1266 days
#13 posted 327 days ago
You need to know what your AHJ (Authority Having Jurisdiction) calls for to meet whatever they’re using for code. (Electrical codes are NOT universal). If they’re happy, you should be fine.
You should be able to determine the gauge of your wire by pulling a receptacle (turn off the breaker first) and looking at the wire jacket. Typically, they’ll have printing telling you the gauge AWG10 would be 10 gauge. AWG20 would be 20 gauge. If your 220v circuit has AWG12 or AWG14, don’t even turn the breaker back on. – lol
You’re probably ok with your DC and TS on the same circuit. Mine are on a 30 amp circuit with 20 gauge wire and do fine. My sequence is to start the DC before the saw so I’m not hitting the circuit with two startup loads at the same time.
