Router Lift, which one do you use
Forum topic by coloradoclimber posted 49 days ago 325 views 0 times favorited 16 replies Add to Favorites
View coloradoclimber's profile
coloradoclimber
279 posts in 516 days
49 days ago
Topic tags/keywords: router lift prl woodpecker
I’m considering getting a router lift, in particular I’m looking at the Woodpecker Precision Router Lift. With an adapter collar and a set of rings it’s well over $400. Before I drop that kind of money I’m curious what other lumberjocks are using.
View GaryK's profile
GaryK
8409 posts in 437 days
49 days ago
That’s the one I have, but I didn’t have to buy the adapter since I already had a big PC router.
I am very happy with it.
Before that I had an old Jessem/Roclker Mast-R-Lift that had a cogged belt which kept slipping if you didn’t
keep it really clean. So I got the Woodpecker PRL and haven’t looked back.
View Russel's profile
Russel
1214 posts in 388 days
49 days ago
I’ve had a Jessem for the past couple years and it’s doing everything I ask. I’m sure there’s better, but this works for me.
View brunob's profile
brunob
1388 posts in 618 days
49 days ago
I have the woodpecker- It’s great and very well made. Good customer service as well.
-- Bruce from Central New York
View David58's profile
David58
1 post in 62 days
49 days ago
I bought the Woodpecker PRL about a year ago to replace a Jessem/Rockler FX that also had a slipping problem. I use it with a PC 7518 motor. It does a great job. No problems so far.
-- David S. - South TX
View Mark Shymanski's profile
Mark Shymanski
411 posts in 161 days
49 days ago
Admittedly I am very new to this woodworking stuff but is there a real advantage to an external router lift over those routers that have the through the table height adjustment? I guess I am not clear on what exactly a router lift does.
-- ....next big purchase is wood for the next project, Mark
GaryK
49 days ago
Mark – I would think that an external router lifts are built a lot more heavy duty. The shafts they move up and down on are larger than used on stand alone routers to keep the weight down.
I can’t see a stand along router being more rigid swinging a 3” diameter panel raising bit.
I am not really familiar with the stand alone routers, but I don’k think they have a indicator letting you know exactly how far you are raising the bit, like the PRL does.
The advantage of a stand alone is that you can either take advantage of the feature or not, but then again it doesn’t take much to pop out my router from the PRL and put it back into the base that came with it.
I think a lot of people use a dedicated router in their router table.
Another advantage is the cost.
View sIKE's profile
sIKE
470 posts in 203 days
49 days ago
I have been lots of research on the topic and I have decided to go with a Hitachi M12V and a Router Raizer along with the Xtreme Xtension from the same company. Saw a demo at the Woodsmith Store in Iowa and it just rocked.
View closetguy's profile
closetguy
57 posts in 341 days
49 days ago
I’m using the Rockler lift because I have their table and this one was made to fit the opening in their table. The price was also less than other lifts. http://www.rockler.com/product.cfm?page=10777
As for Mark’s question, I used a plunge router with through the table adjustment for a number of years, and I can tell you there is a world of difference between that solution and the lift. I can adjust my bit height in increments of a 1/4 nat’s hair everytime. The PC plunge router I was using with the “though the table adjustment” had a slight slop and I could never reliably move in small repeatable increments. Moving to the lift also gave me the ability to change the bit from above the table where the plunge router won’t let the collet move that high.
The only downside to the lift is if your router motor is not removable from the frame, you will have to buy one that is, or buy just the motor because the lift is design to clamp around a bare motor.
-- Dennis... www.closetdreams.com
3973 posts in 667 days
49 days ago
I hope we’re not getting off the topic, but I wanted to add my thoughts to what Dennis and Gary said.
I have a Triton plunge router with through-the-tabl;e adjustments, and I certainly can make above-the-table bit changes. That was my main reason for getting it. And as for the solidity issue Gary brought up, my router’s base bolts directly to the table, so I don’t see how you can get any steadier than that.
I do agree, though, that the big advantage of a quality lift is the precision and repeatability of the height adjustment.
GaryK
49 days ago
Charlie – What I meant about the solidity, are the diameter difference in the two shafts between the PRL and a regular plunge router.
These 2 shafts are what router is hanging and sliding up and down on. The PRL shafts are greater than 1” in diameter. Which are larger than any plunge router I have seen. The bigger these shafts the less they flex.
It’s pure physics that a 3/4” shaft will flex more then a 1” shaft.
Then there’s the base. It would depend on what your router’s bolted to. If your router base were bolted to a piece of 9” x 12” x 3/8” thick aluminum or the equivalent I would agree that in that aspect would be just as solid.
This is a gross overstatement and I use it only to help someone visualize, but imagine bolting your router base to a piece of cardboard vs. a piece of steel. When bolted to cardboard it would only be rigid to the diameter of the router base and the rest would flex.
Depending on all the factors involved I would say that a lift would be more solid. The difference may be small but “in my opinion” it would be there.
BTW I forgot to mention that you can also change the bit above the table and as Charlie stated he could also do that on his Triton, so I would imagine it would depend on the router and how thick your table top was.
48 days ago
I understand now what you were saying, Gary, and you’re right. A plunge router is inherently going to have a tiny bit of play in it. But seeing as wood cannot really be worked to the same degree of precision that metal can anyway, I doubt it would be an important practical consideration. Flex in the table and/or base plate, as you described, would probably be a much bigger factor.
View Loren's profile
136 posts in 97 days
48 days ago
Veritas makes a clever “router jack” that is inexpensive and might
fit the bill.
Undoubtedly the Jessem lifts are nice. I owned a Jessem sliding table
and the engineering and manufacturing were top notch.
I have never used a router lift myself though. I know that may seem
like heresy. The way you feed and apply pressure to the work
affects the cut more than you’d think it should. If I wanted
repeatability I would buy a power feeder before a lift because that
minimizes operator feeding error, often an issue with both joinery
and profiling.
A lift adds weight to the table as well…. and MDF will sag under
even a 12 lb. router so the lift may magnify the error. I had a
Veritas steel router top that I liked quite a bit because I
knew that inaccuracies would only be coming from me, not issues
with the table.
I’ve been impressed with the thoughtful designs of the Woodhaven
stuff so you might want to check out their system, especially the
tilting router gizmo
I have a Milwaukee router with a hole in the base plate for a long
allen wrench type tool. I never drilled a router table top for it but
it seems to me that between that and some inexpensive machinest’s
gauges you could get very accurate setups. I have an old Brown
and Sharpe height gauge and it’s practically worthless on Ebay but
real handy for checking jointer knives and other precise setup tasks.
-- Need help with marketing your business? Look in my profile.
Mark Shymanski
48 days ago
Thanks Gary and Dennis for the explanations. I can see where the increased rigidity would be an asset in getting repeatable results.
coloradoclimber
48 days ago
Point well taken on the table sag. The lifts themselves are heavy, and when coupled with a big router you could certainly see the table sagging. Multiple of the manufactures I checked out recommended either a large stiff table or retrofitting stiffeners into an existing table if you are going to use these bigger lifts and motors.
I am planning on building a custom cabinet and I’ll build in additional stiffeners around the plate hole.
Given what I’ve seen and read recently it looks like there are many heavy duty router lifts that work very well. The woodpecker, bench dog, and jessem (and rebranded incra jessem) lifts all consistently get very good reviews, even carrying the largest routers.
closetguy
48 days ago
I smiled at your reply CharlieM because when I made the comment about the lack of above the table bit changes I started to put in parentheses (except for those lucky enough to have a Triton). I was stuck with a Porter Cable at the time. :)
View EEngineer's profile
EEngineer
28 posts in 62 days
47 days ago
Gotta put in my .02 worth…
I am using the Woodpecker Quicklift in my router table with a DeWalt 616 and a reducing collar. Altogether about $280 (minus router). The really lovely thing about this setup is that, by inserting the lifting rod and turning 90 degrees, the entire router pulls up far enough above the table for bit changes. All without turning the adjustment crank endlessly to get the router above table height. After the bit is changed, the same process returns the router to approximate cutting height. I keep a depth gauge in a drawer under the router table, and using that and the adjustment crank that came with the lift puts the router at perfect cutting height in seconds. I simply cannot tell you just how smooth this process is but it makes using the router and router table an absolute joy. See thier website (www.woodpeck.com) for a better explanation than I can give you.
The Quicklift is made extremely well, rugged and solid with virtually no backlash and no “creep” in adjusted height while cutting. I intended to buy the Jessem FX lift because it was cheaper. After seeing both units out of the box, however, I spent almost $100 more (I think, it was over a year ago) on the Woodpecker Quicklift; it just seemed much more solid and the Quicklift feature seemed like a plus. After a year of using it, I am sooo glad I did.
Now, one caveat; I think they use a split threaded block to achieve the Quicklift feature. I had some concerns about strippinbg this block when I purchased the unit. After a year, however, I have had no problems. The feature is so useful that, even if it proves to be a problem long term, I will either fix the unit I have or buy a new Quicklift to replace it if it ever does strip out.
Bookmark And Share This Page
