Electolysis
Forum topic by Eric posted 07-22-2012 06:14 PM 1095 views 0 times favorited 7 replies Add to Favorites Watch
View Eric's profile
Eric
221 posts in 2632 days
07-22-2012 06:14 PM
Is galvanized metal ok for electolysis rust removal? I know stainless steel produces harmful byproducts.
-- Eric
7 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3189 days
#1 posted 07-22-2012 06:38 PM
Look up “Electrolytic Rust Removal”.
It’s been many years since I studied Materials Science, but I believe that galvanization is a process to “grow’” a protective corrosion layer on metal. As long as the galvanizing is intact, further corrosion is either stopped or at least slowed. I’m not sure how you could use one type of corrosion to remove another.
View Eric's profile
Eric
#2 posted 07-22-2012 06:46 PM
I have some galvanized hanger strap I’d like to use to make a comductive connection between my three raw metal anodes. Its only purpose is to conduct the charge in this case.
I’ve looked online. The only thing people talk about is DON’T USE STAINLESS, DON’T USE STAINLESS!
-- Eric
View ajosephg's profile
ajosephg
1880 posts in 3681 days
#3 posted 07-22-2012 07:05 PM
Would not be good. Galvanized steel is essentially zinc plated and if you use it for an electrolysis electrode you most likely would end up with zinc on your work piece. There may be other adverse safety issues as well.
If you keep it out of the bath (liquid) there would be no problem.
-- Joe
View Eric's profile
Eric
#4 posted 07-22-2012 07:17 PM
Ok. Thanks guys. I found an old steel tool box tray. That will give me even more surface area.
Joe – You will never guess what I’m cleaning. :-) haha
-- Eric
ajosephg
#5 posted 07-22-2012 07:30 PM
Hmmm – gotta be pieces and parts from a Unisaw??
-- Joe
View Eric's profile
Eric
#6 posted 07-22-2012 07:42 PM
Yes, sir! So excited! When I got there it appeared pretty cruddy aesethically. Nothing that couldn’t be cleaned…. I just have a lot of cleaning. Hand wheels are smooth; fence is rock solid. Any special tips for maintenance inside while I have the top off?
-- Eric
ajosephg
#7 posted 07-22-2012 08:57 PM
I like Lubriplate (white lithium grease) for bushings that are protected from saw dust and spray on moly lube (I used CRC brand) for the rack and pinions. (It is real slick and is dry, so saw dust doesn’t stick to it.).
Other than that just stroke all the parts and tell them that you love them.
-- Joe
