Butternut kitchen counter
Forum topic by Stormy posted 07-22-2012 05:35 PM 1333 views 0 times favorited 5 replies Add to Favorites Watch
View Stormy's profile
Stormy
164 posts in 2161 days
07-22-2012 05:35 PM
Topic tags/keywords: finishing
I want to replace our yellow formica counter top. The cabinets are smooth birch with very dark stain and the butternut will contrast nicely plus add the natural wood grain. I’m thinking mgf backing with butternut laminated on top, both for thickness and strength.
Has anyone used butternut for such a project and what would be the best finish for water resistance and general kitchen use?
-- Stormy: Sometimes the wood just tells you what it wants to be.
5 replies so far
View tyskkvinna's profile
tyskkvinna
1310 posts in 2949 days
#1 posted 07-22-2012 05:45 PM
butternut is very porous and soft.. if I was going to use it, I would only use it under an epoxy or resin.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View HerbC's profile
HerbC
1740 posts in 2823 days
#2 posted 07-22-2012 07:47 PM
Unless you’re using veneer thickness material laminating solid wood panels to manufactured panels such as MDF or plywood is not a good idea. The solid wood will expand and contract with changes in moisture and will cause the panels to eventually destroy themselves.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View knotscott's profile
knotscott
7980 posts in 3339 days
#3 posted 07-22-2012 08:04 PM
I’ve used butternut for a closet door…..great looking wood, strong enough, and it’s light, so it worked out well for a door. I agree that butternut isn’t a great wood to expose to moisture. On the plus side, it works pretty nicely, but I’d cover it in epoxy or resin as Lis suggested, or wood consider a different wood.
View WoodYard's profile
WoodYard
35 posts in 2975 days
#4 posted 07-27-2012 12:25 AM
I put Mahogany counter tops in my kitchen a couple of years ago. I would think Butternut is too soft but I’m no expert. There was a good article in Fine Homebuilding about 2 1/2 years ago on wood tops.
-- Rick Wood TheWoodYard.com
View lumberjoe's profile
lumberjoe
2899 posts in 2212 days
#5 posted 07-27-2012 12:35 AM
All the butternut I have seen needs A LOT of work to get into usable shape. Tons of huge knots, splits, and defects. I have about 8 board feet that I need to do something with
