Staining with water-soluble dyes (TransFast) sprayed with plant mister?
Forum topic by Millo posted 07-22-2012 03:46 AM 1632 views 0 times favorited 6 replies Add to Favorites Watch
View Millo's profile
Millo
543 posts in 3288 days
07-22-2012 03:46 AM
I don’t have a spray system and don’t want to buy one now (b/c I can’t afford a good one and would rather buy other tools) and yup, someone recommended the technique mentioned in the title to me months ago and I just simply stopped pretty much woodoworking on my little projects while I took a course, and now I ahve a huge log of unfinished little insignificant projects here and there. Now that I’ve decided I got to go back and finish everything, etc. I got to think: “WHAT? A LOWLY WATER BOTTLE WITH A SPRAYER?” So, has anyone stained using TransFast on figured soft maple spraying it with a plant mister? Or should I just get Charles Neil’s blotch thingy and wipe the stain?
Thanks!
View Woodknack's profile
Woodknack
12464 posts in 2618 days
#1 posted 07-22-2012 08:26 AM
That’s the only way I’ve ever used dyes. Spritz them on. Works perfectly.
Millo
#2 posted 07-22-2012 01:09 PM
Any spritzer? Should I look for a specific type? Whatever’s available at my local walmart or supermarket?
View HalDougherty's profile
HalDougherty
1820 posts in 3475 days
#3 posted 07-22-2012 02:24 PM
I use them often in solution in denatured alcohol and apply them to maple with a corner of a paper towel. I just wipe on each color, let it dry, and sand as much of the color off as needed before I apply the next color.
-- Hal, Tennessee http://www.first285.com
Woodknack
#4 posted 07-23-2012 08:45 AM
Any spritzer, sure. I wouldn’t go too cheap though as you know that flimsy ones tend to spit more than spray. I bought one intended for mixing cleaning solution, has an adjustable spray, and it works fine. You could probably reuse a Windex bottle or something.
Millo
#5 posted 07-24-2012 01:18 PM
Cool. I’ll look around see what I find. Thanks
Millo
#6 posted 08-11-2012 04:14 AM
