| Forum topic by StephenSchaad | posted 332 days ago | 1823 views | 0 times favorited | 17 replies | ![]() |
332 days ago |
Topic tags/keywords: end grain cutting board board cutting end grain wood floor hardwood hardwood floor bamboo butcher butcher block I was watching DIY network yesterday, like always, and one of the projects they did was using left over bamboo flooring to make end grain cutting boards. I was just thinking about buying some solid hardwood flooring, plane it down, glue it up and make some end grain boards with it. Any one do this or know why it wouldn’t be a good idea? I think the price is unbeatable but since dimensional lumber from woodcraft is so expensive its tough to compare. They have hard maple flooring for around $3 or so a square foot. I wonder if this is a good way to save some money on cutting boards. |
17 replies so far
#1 posted 332 days ago |
A couple of issues with this plan: If you buy prefinished flooring you’ll find the finish is “very” hard and will really dull your planer blades quickly. You will loose close to 25 percent of total volume of the lumber when you plane down the relieve grooves on the back of the flooring. Look for a local sawmill and buy rough cut lumber directly from source. You can save a lot of money doing that. Herb -- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090 |
#2 posted 332 days ago |
I have re-purposed bamboo for counter tops in my kitchen. Beautiful! BUT – the finish that is on the wood out of the box will drive you nuts trying to remove. I sanded with a belt sander for hours over a 2×5 foot area!! Also, note that the bottom of each board is recessed so, you won’t find it easy, out of the box, to cut and glue end grains. Good luck. -- Max the "night janitor" at www.hardwoodclocks.com |
#3 posted 332 days ago |
ahhh… Ok so it’s only a decent project if it’s literally going to go to waste. I didn’t know about the back being curved in like that Charles. I’ll have to take a look at the boards and see if they have it. Thanks for the response guys |
#4 posted 331 days ago |
I sell old flooring for lumber all the time… :) It works great.. wood is wood. If it has finish don’t bother removing it with anything short of a planer or saw. If you have a bandsaw or table saw I’d suggest cutting just inside of it and then smoothing it. Easier on the blade. -- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt |
#5 posted 331 days ago |
I saw that show also but I missed part of what she did to create the cutting board. I had my head stuck in the frig! :-) -- Handcrafted by Mike Henderson - Channelview, Texas |
#6 posted 331 days ago |
My local hardwood flooring firm lets me have all the old floorboards i can carry away, oak, maple beach etc. -- ... Never Apologise For Being Right ... |
#7 posted 331 days ago |
Hey Stephan – when I was starting out in woodworking some of my first wood scores were small lots of flooring on Craigslist for real cheap. like $0.50 square foot… As mentioned above, the pre-finished stuff is nasty to deal with – but I have found many uses for it around the shop. Such as building a french cleat system on the wall, etc. Some info here: http://lumberjocks.com/JL7/blog/18717 Also – 3 of the cutting boards in this post are from flooring: -- Jeff - I have not failed. I've just found 10,000 ways that won't work. |
#8 posted 331 days ago |
I wouldn’t use bamboo because all you can get is prefinished. I’d use unfinished hardwood, since I don’t think I’d trust anything prefinsihed to be food safe. Its a oil based polyurethane with aluminum oxide additives. When you sand it it will spark. Talk to your local wood flooring place and see what they sell unfininished. Most places are switching to mostly prefinished now, but unfinished should be easy enough to find, only issue is you’‘ll have to buy at minimum a bundle usually which will be approx 20 sq ft at $3 a foot is a lot than dimensional lumber, though If you do a few cutting boards it should pan out though -- It's made of wood. Real sturdy.--Chubbs Peterson |
#9 posted 331 days ago |
Also, bamboo flooring is not just a piece of bamboo like wood flooring is a piece of wood. Bamboo is a manufactured product. What do they use in those products. Check the MSDS sheets, since sometimes I know they claim to be formaldehyde free, which to me means sometimes other are not formaldehyde free. -- It's made of wood. Real sturdy.--Chubbs Peterson |
#10 posted 331 days ago |
Ben, you’re right… Bamboo is all laminated together so I most likely wouldn’t go with that. Jeff, I loved those links. I know there’s plenty of good lumber in unfinished hardwood floors but I guess getting the wood is the difficult part at a good price. I’m going to a scrap yard this week so I’ll see what kind of floors they have there. I think they had a basketball court the last time i checked but I’d have a hell of a time getting the clear coat off those. Lis, you’re right… Cut the clear off and plane it after. Much better to use an old table saw blade than my expensive planer blades. haha Thanks for the responses. |
#11 posted 331 days ago |
I wouldn’t do this with any prefinished floor material. They have an aluminum oxide based finish that is incredibly hard (that’s why it’s so durable in high traffic areas). It’s pretty rough on saw blades and I don’t want to think about what it might do to planer or joiner blades. If you want to find out for yourself, use your own machine ‘cause you ain’t getting close to mine. – lol Unfinished or reclaimed hardwood (the “real” stuff) should work fine, but I would pass on the prefinished stuff. Someone said that bamboo is a manufactured product and that isn’t exactly correct – bamboo is a type of grass. I really don’t know how it gets turned into flooring, but the “feed stock” is just grass. It has really gotten popular as flooring material because it’s “different”, nice looking, and “green”. It grows like a weed and can be harvested very frequently. If you’ve ever tried to control ornamental bamboo in your yard, you know what I mean. Take anything you see on a DIY show with a large grain of salt. Most “pros” roll their eyes at some of the stuff they do. – lol -- Adversity doesn't build character...................it reveals it. |
#12 posted 331 days ago |
For what it’s worth, the floor I use daily (and sell) WAS basketball court. Saws right off and barely penetrates. From what I’ve learned on the subject they generally use an epoxy-type or poly-type “top coat” rather than “penetrating”. You ultimately use less that way and goes fast in installation. I would be willing to guess any basketball court floors you find will be similar. -- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt |
#13 posted 330 days ago |
I have used a lot of pre-finished hardwood flooring for projects. In my opinion a drum sander with 50 grit paper is the only way to remove that finish (and it works fast and easy). I wind up with 5/8” stock after I sand off the finish and plane the grooves off the back (starting with 3/4” flooring). -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#14 posted 329 days ago |
sawkerf…I should have clarified that bamboo flooring as well as really any other bamboo tray, cup, silverwear holder, or anything else you see made from bamboo is at the bare minimum, stalks of bamboo laminated together. Strand bamboo (the really hard type of bamboo) is bamboo stalks that have been shredded and reconstituted under high heat and pressure and who knows what else. My claim as bamboo being a manufactured product is that you don’t cut a piece of bamboo and then run it through a planer or saw like you can with oak or pine or any other type of lumber. -- It's made of wood. Real sturdy.--Chubbs Peterson |
#15 posted 329 days ago |
Ben – I have a stash of bamboo plywood and I agree with tour statement about running it through the planer, I haven’t tried it, but it doesn’t seems like a good idea. You can however, process is just like wood in most other ways. Tablesaw, sanders, etc….no problem. Just have to really be careful of slivers!! -- Jeff - I have not failed. I've just found 10,000 ways that won't work. |
| Forum | Topics |
Woodworking Skill Share
8845 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15977 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2775 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
