Block plane with chip missing behind throat
« back to Hand Tools forum
Forum topic by Brett posted 07-21-2012 10:26 PM 1718 views 0 times favorited 9 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2558 days
07-21-2012 10:26 PM
I bought a 60 1/2 block plane that has a piece missing behind the throat. Will this affect the performance of the plane significantly?
-- More tools, fewer machines.
9 replies so far
View Arlin Eastman's profile
Arlin Eastman
4083 posts in 2437 days
#1 posted 07-21-2012 10:44 PM
OO
That is kind of a big chip. I know for sure if it was in front that would be bad, however, a piece that big will not support the blade very well either.
Must see what Bertha says on this one.
Arlin
-- Please help me help other Vets click..> http://www.gofundme.com/m1abko.....It is always the right time, to do the right thing.
View bandit571's profile
bandit571
18938 posts in 2559 days
#2 posted 07-21-2012 11:12 PM
That might make the iron “chatter” as it goes along. On a small plane it will be worse. On the larger ones, not so much….
On this #8c, the frog sticks out and supports the iron, a block plane has no frog for that. Does my #8c work?
Seems to. Again, this has a frog for support.
View Don W's profile
Don W
18564 posts in 2443 days
#3 posted 07-22-2012 12:15 AM
I don’t think it will hurt performance much at all.
View Newage Neanderthal's profile
Newage Neanderthal
190 posts in 2426 days
#4 posted 07-22-2012 01:27 AM
ruint, completely ruint, might as well throw it away.
Nah, its fine, there is plenty of bearing surface for the blade to either side of the cutter, and its sitting in there at 12 degrees, not getting much blade flex at all from that angle.
-- www.newageneanderthal.blogspot.com . @NANeanderthal on twitter
Brett
#5 posted 07-23-2012 06:17 PM
The rest of the plane seems fine. Is there any way to fix the chip?
View Loren's profile
9774 posts in 3523 days
#6 posted 07-23-2012 06:28 PM
You can fill it with solder or braze it.
View NiteWalker's profile
NiteWalker
2736 posts in 2452 days
#7 posted 07-23-2012 10:01 PM
What about something like jbweld? I know it fills in cast iron imperfections pretty good.
Newage Neanderthal
#8 posted 07-23-2012 10:23 PM
JBweld isn’t really structural, it may work for a bit, but its more of a gap filler than something that can take a full on edge beating.
Don W
#9 posted 07-23-2012 11:53 PM
I’d us it as is. Trying to fix it could make matters worse. I doubt you’ll notice it during use.
If it bother you, keep an eye out for a parts plane with a good base.
