| Forum topic by Milo | posted 332 days ago | 783 views | 0 times favorited | 18 replies | ![]() |
332 days ago |
Topic tags/keywords: question miter saw Hey gang, The draw on my sliding mitre saw. It’s a POS I picked up at a garage sale, but it runs, and I’d to see if I can salvage it. When I push (or pull) I don’t get a straight, 90 degree cut to the length of the board. Say, after the cut, I have a 2 foot board on one length, I have 2’ 1/8 on the other. Is there a way to fix this permanently? Is my only recourse to play with the angle adjustment on the table? I appreciate the advice. Here are a couple shots of my CSMS.
If you have any ideas, let me know! Milo -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
18 replies so far
#1 posted 332 days ago |
Uhhhh? POS? Why didja buy it? -- bill@magraphics.us |
#2 posted 332 days ago |
It obviously does not SLIDE in a straight line. Good luck! -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#3 posted 332 days ago |
Loosen your back rail and square it to the blade. -- Government does not solve problems; it subsidizes them. |
#4 posted 331 days ago |
Bill, You’ve never bought spur of the moment and regretted it later? ;) -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
#5 posted 331 days ago |
Maybe this will help you Milo. To check that your miter saw is cutting true, take a board that is near the cutting capacity of the saw in width, and say 18”+ long. With the saw set to 0° cutting near the center of the board make a cross cut. Now flip one of the pieces you just cut over, placing the side that was closest to you to the fence. Butt the cut together and check for a gap. If there is no gap your saw is cutting true. If there is a gap, adjust saw until a tight joint is achieved. Same technique applies for the bevel settings of a saw. -- Darrell, making more sawdust than I know what to do with |
#6 posted 331 days ago |
Again, look at post 3. IMO, Thats all thats needed to adjust. -- Government does not solve problems; it subsidizes them. |
#7 posted 331 days ago |
I adjust mine like Darrell and Jim. I loosen one end of the fence and leave on end tight. Tap the loose end with a hammer. And draw a line along the fence on the base to see if it’s moving and how much. -- "Actions speak louder than words but not nearly as often." - Mark Twain |
#8 posted 328 days ago |
I’ll see if I can do that Jim. Took me a while to figure out what your were telling me, then, light bulb!. Hope that rail doesn’t move with the fence though… :( -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
#9 posted 328 days ago |
What rail? -- Government does not solve problems; it subsidizes them. |
#10 posted 328 days ago |
Take a day off from woodworking. Go fishing. Use saw for boat anchor. “Lose” anchor. Find new saw. -- Don't rollerskate in a buffalo herd |
#11 posted 328 days ago |
Can’t tell what brand it is, but that back “rail” looks like the one on my Makita SCMS. Mine has two bolts (one at each end) that allow it to be squared to the blade. Set the saw to 0* and lock it in the down position. Use a square (a speed square should work fine) to align the back “rail” to the blade and tighten the bolts. Piece of cake and shouldn’t take more than a couple of minutes. -- Adversity doesn't build character...................it reveals it. |
#12 posted 328 days ago |
“You’ve never bought spur of the moment and regretted it later?” Yep! Though I didn’t “buy” my first wife. I also bought some MinWax stuff, but that’s another story. Bill -- bill@magraphics.us |
#13 posted 327 days ago |
This is a true POS guys. The back fence does NOT move independent of the table. Yeah! But see that knob in the first picture, on the right, behind the fence? It locks the table in place, even the 2 degrees I need to make it square. yeah! I think I found my solution. Now to get some scrap and test until I get it right. THANKS GANG! You guys are the best. Milo p.s. Howie, strongly considering your ideas…. ;) -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
#14 posted 327 days ago |
What does POS stand for? -- My terrible signature... |
#15 posted 327 days ago |
Piece Of S#@$..... :) -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
| Forum | Topics |
Woodworking Skill Share
8845 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15977 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2775 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
