"Tung oil" finish. When to quit.
Forum topic by SuburbanDon posted 07-21-2012 05:44 PM 20132 views 0 times favorited 11 replies Add to Favorites Watch
View SuburbanDon's profile
SuburbanDon
487 posts in 2865 days
07-21-2012 05:44 PM
Hi,
I’ve been applying Formby’s ‘Tung Oil’ finish to unstained cherry. Sanding with very fine paper between coats. Following Bob Flexners advice. Most of it looks pretty good and shiny but parts don’t. Any ideas on how to proceed or should I just get while the gettin’ is good ?
Thanks, Don
-- --- Measure twice, mis-cut, start over, repeat ---
11 replies so far
View Alster's profile
Alster
100 posts in 3085 days
#1 posted 07-21-2012 05:55 PM
Keep going until it is all uniform. I used (which is really wiping varnish and not Tung oil) on a cherry table, and it took many coats until I reached the point where the finish was even. I think it is just so thin that it soaks into the wood very readily. Don’t give up!
View DeputyDawg's profile
DeputyDawg
196 posts in 3836 days
#2 posted 07-21-2012 06:36 PM
Years ago I refinished a gun stock and it took 22 coats sanding with 0000 steel wool. It turned out beautiful and the depth of the finish was remarkable. Thought I was going to go nuts but it was worth it
-- DeputyDawg
SuburbanDon
#3 posted 07-21-2012 06:48 PM
Ok thanks. I will hang in there. The finish is not that important for this project but I’m trying to step up my finishing skills.
View Dusty56's profile
Dusty56
11814 posts in 3559 days
#4 posted 07-21-2012 06:52 PM
Was Bob using real Tung Oil , or Formby’s ?
Does their label say to sand between each application ?
Are you sanding because of dust nibs , etc. in the finish ?
Formby’s is 70% Mineral Spirits and the balance is modified soya and tung oil with Alkyd Resin.
Not much room in there for Tung Oil. It’s actually known as a wiping varnish and will take many , many coats to build up evenly.
View Bill White's profile
Bill White
4819 posts in 3831 days
#5 posted 07-21-2012 07:19 PM
Formby’s is a tung oil varnish. Great finish, but needs lots of coats to really look good. Keep workin’ on it. You’ll be pleased. I used it on a walking stick. Took about 2 months of multiple coats ( maybe 10), but the results were very good.
By the way, I had lots of time.
Bill
-- bill@magraphics.us
SuburbanDon
#6 posted 07-21-2012 07:51 PM
Their label says to use 0000 steel wool after each application. I tried that but somehow prefer to sand to 400 grit.
Dusty56
#7 posted 07-22-2012 02:23 AM
The 4 ought steel wool just scratches the surface enough to make the next coating adhere better, whereas the 400 grit is actually removing the last coating, making more coatings necessary to build up the sheen, and more work for you in the end : )
View MonteCristo's profile
MonteCristo
2099 posts in 2059 days
#8 posted 07-23-2012 09:18 PM
I would base the number of coats on how good it looks and how heavily it will be used. More coats for heavy use items obviously.
View Doss's profile
Doss
779 posts in 2135 days
#9 posted 07-23-2012 09:32 PM
Depending on the quality of the sandpaper and steel wool being compared, 0000 is equivalent to 600-800 grit sandpaper (some say even as high as 2000 grit).
They don’t “cut” in the same fashion though and the results will vary because of this. I’d say if you must keep using sandpaper, to at least step up to 600 grit.
And yes, sometimes it does take a lot of coats to get an even looking finish.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View gfadvm's profile
gfadvm
14940 posts in 2561 days
#10 posted 07-24-2012 01:47 AM
Don, I don’t know how similar MinWax Tung Oil Finish is to what you are using, but I have great success applying Tung Oil Finish with a cotton cloth and then continuing to rub until it is dry to the touch.Repeat once a day for 3 applications. I have not done any sanding or steel wooling with this method and get a very nice end result. I apply Renissance Wax with a white Scotch pad after the finish is cured to give it that silky/ touchable feel. I’ve posted several projects finished this way you can look at.
SuburbanDon
#11 posted 07-24-2012 01:04 PM
Thanks for all of the advice. Since I’m out of work, I’m going to do some practicing on scrap instead of a project. Most of this project looks very good and I’m going to stop because it will mostly be hidden (it is a stand for a round shadow box). I’ll post a picture soon.
Thanks again.
