New Hand Saw advice? Stanly/Irwin...
Forum topic by jtdyal posted 494 days ago 668 views 0 times favorited 8 replies Add to Favorites Watch
View jtdyal's profile
jtdyal
47 posts in 543 days
494 days ago
Topic tags/keywords: saw hand tool hand tools
I LOVE TOOLS! But my love appears to be changing. Last week I had a 1×3 that was 42” long and needed to be 40” the closest tools were my dovetail saw and compound miter saw. I grabbed the dovetail saw and trimmed it by 2”.
The I said to myself “why did I do that?” My chop saw was ready and waiting, it would have only taken 3sec the dovetail saw took like a whole min. I remember smiling when I was done with the cut. It felt good.
It was a nice, clean, square cut. But I really think it was the sound. “vvvet….vvvet…vvvet…” that makes the experience of hand saws. I have used it before when my jigsaw would do, but was let down when the thin kerf wouldn’t let the thick brass pass and I can’t go any deeper.
So I have Lowes gift cards I need to use. And I would like a saw that will let cut rip a board if I am so inclined. And I can save my dovetail saw for smaller joints. Anyone got some advice on what to look for? Does this mean I am turning into one of those “hand tool guys”? Or do I just need to forget the sound and buy more clamps?
-- ~jtd
View Loren's profile
347 posts in 541 days
494 days ago
I use Japanese style pull-saws for a lot of work. If you
don’t have a pull-saw I’d recommend getting one. Even
though I prefer the one’s with the bamboo-wrapped handles
I’ve seen some decent-looking ones at Big box stores.
I’d avoid the Shark saw brand of pullsaw. The blades are
flimsy. I prefer the saws with the stiffer blades.
For cutting bigger dovetails I use a self-made bowsaw. I
bought a butcher saw blade, refiled the teeth for ripping,
and filed most of the set off the teeth – works like a charm
for straight rip cuts in end grain.
-- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html
View dsb1829's profile
dsb1829
369 posts in 521 days
489 days ago
I think Loren hit it on the head. The Japanese style saws have won me over. I had one in my garage for about a year, but never used it. Once I started it quickly became my goto saw for quick one offs. The saw I use is a double edges ryoba. I have also picked up a zero set flush trim saw. Both of these pull saws are worlds easier to control than the traditional back saws I had been using. The ryoba is a good saw to have since it is a combo blade one side is higher tpi and set for cross cutting, the other side is lower tpi and no set for ripping.
-- Doug, woodworking in Alabama
View GaryK's profile
GaryK
9521 posts in 882 days
489 days ago
I’m with the rest. For hand cuts I use a pull saw that is two sided. One for ripping and the other for cross suts.
Works great and it’s very fast. Like Doug I also use a flush cut saw all the time.
View Rob Drown's profile
Rob Drown
324 posts in 726 days
484 days ago
Pull-saws are a must have tool. Accurate easy to use and able to trim very close.
-- Sharp tools and thin whispy shavings make woodworking a joy.
View tenontim's profile
tenontim
1319 posts in 638 days
483 days ago
The Japan Woodworker and Lee Valley carry nice saws. I’ve bought saws from both that are ground for ripping.
The rip saws are great for cutting tenons. They have a back spline on them to keep them tracking straight. I had problems with the two sided Dozuki saws wandering, so went with the dedicated saws. You might want to use your Lowe’s card for something else.
-- Tim -- http://tmuli.com
View 3fingerpat's profile
3fingerpat
906 posts in 561 days
483 days ago
I laughed for sometime when reading your post, I haven’t used my chop saw in over two years and I am currently residing my house. I have several small handsaws (Western style backsaws, I recently posted a review of these saws in the review section) and a couple of Japanese pull saws which I use for smaller work and I have two 26” Lynx Handsaws (one rip and one crosscut) which I use for larger work. I use the Western Style saws before I would use my Japanese saws, but that is just my preference. I also I have a Wenzloff half back saw but it has only seen limited useage and I am not that enamored with it yet. I know that the types of saws I use are not at Lowe’s but I thought I would throw in my 2 cents in case you hadn’t been exposed to other makers\types of saws. Good luck and keep us posted on what you pick up and how you like using it.
View Napaman's profile
Napaman
3482 posts in 970 days
483 days ago
this is a great question…jtd…I have only a couple small hand saws…and while completing my deck i need something larger since my chopsaw does not have a large enough opening…and I am thinking of getting a new one…but from this strand I see maybe I need to invest in some better hand saws…
I actually bought a “multi-cut” saw—-that I would have called a cross-cut saw—-but I guess it will cut both ways??? to do what we needed…
Now I want to look into some the saws mentioned here…so thanks everyone!!!
jtdyal
483 days ago
OK I was sold. It’s is gonna take some time for me to get used to this thing though. The fine side is not so bad. But ripping with the coarse side is a little awkward. I selected the IRWIN double edged pull saw.($20 @ da BORG) It has a long handle/stick for a handle.
I’ll post a review once I learn to use it.
-- ~jtd
