Maloof rocker with a stripped screw
Forum topic by yellowtruck75 posted 332 days ago 745 views 0 times favorited 8 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
333 posts in 1264 days
332 days ago
So today I was working on my newest Maloof rocker, this one built from 8/4 tiger maple. I was done for the morning grinding and sanding and decided to put the screws in the legs. I was using 3” stainless steel square head screws and half way through the 10 screws I stripped one out with the head just barely sticking out. Initially I freaked out and had to remember to not screw out curse words because the neighbor kids were out :). I decided to use a 1/2 drill bit to remove the head and then plug the rest of the screw under ebony. While I was using the 1/2 drill bit I realized that I took the stripped part off and was able to reseat the square headed bit. Thought I would share my little situation so that if anyone else faces this problem they have a solution.
Stripped screw
After using 1/2 drill bit
Small bit of metal shavings
Success
8 replies so far
View waho6o9's profile (online now)
waho6o9
3066 posts in 774 days
#1 posted 332 days ago
http://www.grkfasteners.com/en/PHE_0_R4_information.htm
GRKs rock, you might want to give them some consideration when doing your fine
woodworking projects. Nice rocker yellowtruck 75!
View Joe Lyddon's profile
Joe Lyddon
6474 posts in 2249 days
#2 posted 332 days ago
COOL TRICK!
Thank you!
View Lee Barker's profile
Lee Barker
1909 posts in 1047 days
#3 posted 332 days ago
Any particular reason you were using stainless screws? Will you continue to use them?
Kindly,
89104 posts in 1774 days
#4 posted 332 days ago
Thanks for sharing. My experience with stainless screws is that they are to soft and tend to strip out or break.
View Wdwerker's profile
Wdwerker
313 posts in 430 days
#5 posted 332 days ago
When I use stainless or brass screws I buy the same exact size screw in steel if available. Pilot the hole and run the steel screw in first, let it thread the hole, then replace it with the softer screw. A little parrafin on the threads helps as well.
-- Fine Custom Woodwork since 1978
Joe Lyddon
#6 posted 332 days ago
I can’t see a brass screw being used in a Maloof type chair… It must be a strong screw… brass is not strong.
IMHO…
For other projects, the steel / brass combo works great!
View sras's profile
sras
3259 posts in 1326 days
#7 posted 332 days ago
Nice advice! Thanks!
View RichardDragin's profile
RichardDragin
4 posts in 1540 days
#8 posted 330 days ago
Nice save!
I use deck screws from the BORG. Dry Lube screws from McFeely’s are also a good option.
