Finishing Oak
Forum topic by SteveGaskins posted 07-20-2012 09:25 PM 1006 views 0 times favorited 7 replies Add to Favorites Watch
View SteveGaskins's profile
SteveGaskins
736 posts in 2460 days
07-20-2012 09:25 PM
I’ve recently refinished a large conference table with Original Waterlox. I love the finish, but on the darker sections of wood within the oak the table feels rough and not silky smooth like the lighter sections of the oak wood. I’ve read in past articles you can utilize some sort of wood or grain filler to fill the porous dark portions of oak before applying the finish.
Do you LJs have any informtion concering this wood/grain filler and how to apply?
Thanks in advanced for your comments.
-- Steve, South Carolina, http://www.finewoodworkingofsc.com
7 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 2942 days
#1 posted 07-20-2012 10:04 PM
The porosity of oak varies a lot as you move across the grain. Filling the pores is a good way to even things up, but it’s usually done before you stain/finish. Might be a real adventure trying it afterward.
404 - Not Found
2544 posts in 2842 days
#2 posted 07-20-2012 10:28 PM
I’m just wondering if the rough patches you’ve got have occurred because of grain raising with the waterbased finish. If you have a reasonable size offcut of the oak, you could try putting the same amount of finish on it, wait till it’s dry, then squeegee on more of the finish (by squeegee, I mean get a good wet coat on it and then drag a clean, straight edge over the top leaving the wet finish in the depressions at the level of the surface) – wait till that is fully dry, if there are still low spots in it, do it again until you have leveled it all over, wait for that to dry and give a final sanding and coat the whole lot again. I’ve done this with great success before, but best try on an offcut first.
I used an old planer knife for the squeegee that was lying around.
View HerbC's profile
HerbC
1708 posts in 2733 days
#3 posted 07-20-2012 10:45 PM
Steve,
Most likely what you’ve heard of is a product known as “paste wood filler” which can be used to fill the pores of open grained woods such as oak and mahogany.
It normally consists of fine particles of silica suspended in a liquid, generally an oil. You applly a coat to the bare wood surface, let it sit a while so the liquid can evaporate and then clean the excess from the surface with a squegee or rough cloth. The trick is to fill the pores without leaving any on the surface. Once you’ve applied the filler to your satisfaction, seal it with a varnish or laquer to seal the surface.
The method described by renners is another way to fix the problem and may be your best course of action since you’ve already applied a coat of finish.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Gerald Thompson
852 posts in 2108 days
#4 posted 07-20-2012 11:39 PM
Waterlox is not water based.
-- Jerry
404 - Not Found
#5 posted 07-21-2012 12:15 AM
Oh, I thought the clue was in the name. If it’s solvent based, it should work even better.
Gerald Thompson
#6 posted 07-21-2012 01:29 AM
Steve;
Depending on the depth of the rough grain you might try adding more coats of varnish to the areas. I did this on an area of a project and it worked. Waterlox can be brushed. It is best to use a good black bristle brush. They hold more product. One has to wait 24 hrs to reapply and no sanding is needed between coats for adhesion.
I use Waterlox a lot and I like it. I don’t know about your brushing talents so you could do a Web search and learn about brushing technique, tipping off, etc.
-- Jerry
SteveGaskins
#7 posted 07-22-2012 01:13 AM
Thanks so much for your input. I knew I would get good feedback from your guys. Thanks LJs.
