Have you a source for these 180o hinges?
Forum topic by Lee Barker posted 07-20-2012 06:05 PM 3108 views 0 times favorited 1 reply Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 3085 days
07-20-2012 06:05 PM
The application is a bar flap, but the same situation exists with these leaves that are coplanar with no hardware showing, and then fold up face to face.
Thanks for your help.
Kindly,
1 reply so far
404 - Not Found
2544 posts in 3203 days
#1 posted 07-21-2012 12:40 PM
From what you are describing, I think you are looking at some kind of hinge for table extension leaves, the hardware won’t show when the flap is down, but it will be visible at the edge when the flap is in the folded position.
I have used the above from Hafele, but they are possibly a bit flimsy for a bar flap, could you use a Soss hinge instead?
