Steel Wool and All Those Pores
Forum topic by Eric posted 500 days ago 292 views 1 time favorited 10 replies Add to Favorites Watch
View Eric's profile
Eric
784 posts in 682 days
500 days ago
Topic tags/keywords: steel wool residue
I noticed that when buffing my recent project with steel wool (00000), there seems to be residue being left in the open pores of the wood. I’ve tried using a toothbrush to get it out, but I’m not satisfied with that.
Is there an alternative to steel wool, or a better way to remove the residue? All I need to do is take off some of the gloss, so would just a nice soft cloth do the same thing?
-- Eric at http://adventuresinwoodworking.com
View pashley's profile
pashley
530 posts in 616 days
500 days ago
You might want to try a Scotch-Brite pad; they leave no residue. Steel wool will also interact with any water you might have in a finish, leaving black specks. I avoid it.
-- http://newmissionworkshop.com
View Eric's profile
Eric
500 days ago
The Scotch-Brite doesn’t leave scratch marks?
View Dorje's profile
Dorje
1767 posts in 896 days
500 days ago
The standard green stuff is pretty coarse (like the kind used for pots and pans), you have to get the “super fine” gray stuff that is similar to steel wool…
Check this out: http://users.ameritech.net/knives/grits.htm#scotch
Also, check out the Mirka Mirlon product/s: http://www.mirka.com/mirlon_wood?mid=5D29A50E-CCF9-48F5-B89B-215ECF31D232&
View Eric's profile
Eric
500 days ago
14932 posts in 750 days
500 days ago
a painters tack cloth might help.
Eric, are you talking about bare wood or painted?.
View Eric's profile
Eric
499 days ago
Wiping varnish.
7675 posts in 1117 days
499 days ago
The big box stores sell sanding sponges. The finest one is great for knocking down a gloss or rubbing out nibs.
teenagewoodworker
2482 posts in 667 days
499 days ago
i heard this from charles neil. haven’t tried it out yet but try using a brown paper bag. he said that it is equivalent to around 4000 grit.
View marcb's profile
marcb
705 posts in 572 days
499 days ago
I use swiffer duster pads to remove dust and steel wool leavings and general cleanup before applying finish. They work GREAT.
View Chris 's profile
Chris
1470 posts in 890 days
499 days ago
Don’t forget that there is also Bronze wool. The local hardware store carries it in stock and it works great. In my experience it doesn’t seem to be as brittle and leave little pieces behind. A friend who does a lot of marine work suggested it to me….
Take a look at this Link. You can also just google Bronze wool for a ton more info.
-- Chris
