Help Identify Unisaw from photos
Forum topic by Eric Criss posted 304 days ago 818 views 0 times favorited 5 replies Add to Favorites Watch
View Eric Criss's profile
Eric Criss
175 posts in 677 days
304 days ago
I’m considering this Unisaw. Can anyone identify the model from the photos? I’m concerned about a three phase motor. The owner could not find the model number tag. Where is the tag on these things?
-- Eric
5 replies so far
View MedicKen's profile
MedicKen
1560 posts in 1628 days
#1 posted 304 days ago
The tag is usually on the rear of the saw, at the top of the cabinet . It looks to be a newer model but for actual model number I dont know and cant help. If its 3ph DO NOT let that scare you away. 3ph motors are wonderful and YOU CAN run them from home for much less than buying a new motor. Get a VFD, variable frequency drive, wire it up and get sawing. The only draw back be if it is a 5hp motor. VFD’s for anything over 3hp are for most cost prohibitive. However, if 3hp or less a good new VFD can be had for under $200. I dont hink you will be able to find a 3hp single phase motor for under $400 new.
Eric Criss
#2 posted 304 days ago
Thanks for the re: Ken. If its 3ph, I think I’m out. The purchase of the saw will tap me dry.
-- Eric
View Rick L's profile
Rick L
510 posts in 1927 days
#3 posted 303 days ago
The tag has nothing to do with the phase of the motor. The tag is on the back of the cabinet at the top.
You didn’t say how much the saw is but the plug end should be an indication. If there is no plug end three phase will have 4 conductors and single phase will have 3 conductors on the wire. This doesn’t guarantee anything for certain as someone may have put a 4 conductor wire on a single phase saw. The real proof is the tag on the motor. Personally I wouldn’t worry about it being three phase as I would put a VFD from factorymation on it. Many folks who don’t understand how to deal with three phase will often sell three phase tools for much less and folks such as yoursell are afraid to touch them because you don’t know the affordable options.
-- Few folks really know how to maximize the potential of their tools!
View MNgary's profile (online now)
MNgary
212 posts in 583 days
#4 posted 303 days ago
I have the right-tilt version with a 3 hp motor – “Delta Classic Edition Unisaw” model 36-815 built in 1998. Delta included a brass plate with the buyer’s name that mounted near the base. The catalog number and the serial number are located on the back side up so high that the fence rail almost completely hides it.
Per the manual, 5 HP was 3 phase. Mine is normal two-twenty volt.
-- "I dream of a world where a chicken can cross the road and no one questions its motive"' - Anne Nonny Mouse
View Loren's profile
4870 posts in 1813 days
#5 posted 303 days ago
Pro shops that buy 3 phase machines these days are
not buying a lot of Unisaws. The Unisaw is just not
a competitive machine in the type of work shops with
3 phase wiring tend to do.
I’m not saying this to bash the Unisaw – but it’s only
a 10” machine and a nice workhorse that doesn’t
weigh too much. I see ads for a lot of used cabinet
saws in my area and the newer 10” saws are seldom
3 phase from any maker. You’ll see 3 phase more
often in 12” and larger machines and of course in
sliders.
