Help diagnose weird tablesaw problem
Forum topic by Rick M. posted 310 days ago 531 views 0 times favorited 8 replies Add to Favorites Watch
View Rick M.'s profile
Rick M.
1497 posts in 551 days
310 days ago
Topic tags/keywords: tablesaw
Lately while using my rip blade it will seem to turn into the wood (toward the fence) every several seconds leaving shallow scars in the cut and only seems to happen while under load. I checked to make sure it was square to the table. I did not check for runout because I don’t have a dial indicator. I switched to my 60 tooth combo blade and the problem went away. Both blades are Freud Diablos. Not sure if it is the blade or something else. Seems like if the blade had warped it would be a constant issue plus the blade appears to run true best as I can judge by eye. It occurs to me that the extra teeth in the combo might be preventing the problem if it’s the saw. Or maybe the nut had loosened a smidgen and I didn’t notice. Never had this problem until recently. Any ideas?
Saw is a ~12 year old Delta contractor. Here is an old pic:
-- -- Rick M.
8 replies so far
View Lee Barker's profile
Lee Barker
1889 posts in 1021 days
#1 posted 309 days ago
My first suspicion: the blade is dull.
Are these thin kerf blades?
Kindly,
View knotscott's profile
knotscott
4202 posts in 1546 days
#2 posted 309 days ago
The fact that the problem only relates to one blade suggests that the problem is with that blade…..Lee’s suspicion is logical. Is the blade dirty by any chance?
The Diablo’s are TK’s…
View Fuzzy's profile
Fuzzy
250 posts in 2159 days
#3 posted 309 days ago
I’ve had something similar happen, and it WAS the blade. A dull blade generates MUCH more heat than a sharp one … it is digging away at the piece instead of slicing through it. That’s why the burn marks appear … and … wood begins to incinerate at about 450 deg F. ... so you KNOW it’s getting pretty hot. Along with the wood getting hot, so does the blade … BUT … instead of scorching, the blade, being made of steel will warp … and it can warp a LOT. I once had a cheap plywood blade warp so bad, it looked like a potato chip. I tried to get a picture of it, but when I got the camera, it had cooled off and was as straight as an arrow !!! If your blade is warping in use … it can be grabbing the piece and pinching it against the fence … by the time you shut it down to check alignment … it can straighten back up, defying detection.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
Rick M.
#4 posted 309 days ago
Thanks all. The blade isn’t that old and hasn’t been burning wood so I didn’t suspect it being dull. I’ll try cleaning it and see if that helps, if not I’ll send it out for sharpening.
Not familiar with that acronym.
-- -- Rick M.
View jmos's profile
jmos
637 posts in 540 days
#5 posted 309 days ago
Thin Kerf – TK
-- John
View patcollins's profile
patcollins
703 posts in 1036 days
#6 posted 309 days ago
Possibly you shaking or not holding a steady line? I found myself fairly shaky and have had to adjust my feed techniques to prevent such things.
View pintodeluxe's profile
pintodeluxe
1754 posts in 984 days
#7 posted 309 days ago
Thin kerf blades will deflect more than full kerf combo blades.
I still like the thin kerf blades becuase they decrease strain on the motor.
Rick M.
#8 posted 309 days ago
Pat, that was my first thought, but since it went away after changing blades it was probably the blade.
FYI, the rip blade is regular (not thin) kerf. I just assumed all the Freud red blades were Diablos, maybe not. I think it’s the heavy duty 24T.
-- -- Rick M.
