need help adding clear finish to soft wood
Forum topic by ssull4167 posted 305 days ago 562 views 0 times favorited 5 replies Add to Favorites Watch
View ssull4167's profile
ssull4167
31 posts in 581 days
305 days ago
Topic tags/keywords: cedar pine
Im wondering if anybody has experience putting on a clear finish on pine and cedar. I dont want to stain it i just want to put a clear finish. Whats the best product to use laquer , poly , sparurethane, waterbasepoly, etc and what is the best procedure. Is there better brands of these products and if so whats the best. Thanks for the input. It will be used indoors sittiing on a shelf
5 replies so far
View waho6o9's profile (online now)
waho6o9
2884 posts in 743 days
#1 posted 305 days ago
I would use sanding sealer first to prevent blotching on the pine and cedar,
as some clear have an amber hue and your work might blotch.
Other’s will have great comments as well.
View chrisstef's profile
chrisstef
5206 posts in 1172 days
#2 posted 305 days ago
I just got finished with using arm-a-seal and loved it on ambrosia maple. General finishes also puts out seal-a-cell which is a sanding sealer. I dont have any direct experience with it but i can vouch for the arm-a-seal. I brused on 2 coats and wiped on another 2 coats.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View tyskkvinna's profile
tyskkvinna
1294 posts in 1152 days
#3 posted 305 days ago
I use Minwax Laquer on cedar with fantastic luck. I like the spray stuff. Several coats later, it is quite glossy and wonderful.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View Jim Finn's profile
Jim Finn
1062 posts in 1088 days
#4 posted 305 days ago
I make a lot of cedar boxes and I use brush on Deft Sanding sealer then Deft brushing Lacquer (Sanding after each coat). I then spray on a clear gloss acrylic finish.
-- In God We Trust
View lumberjoe's profile
lumberjoe
2395 posts in 414 days
#5 posted 305 days ago
It depends on what you are making and how durable of a finish. I would recommend Waterlox. That stuff is amazing. Natural Danish oil is also a good choice and both are very easy to apply. Both are “in the wood” finishes, so you don’t get the plastic look of straight ploy. Follow either of those with a nice buffing with steel wool or some 800+ grit sandpaper, then a coat or two of furniture grade paste wax (not a silicone based automotive wax) and you will have an amazing finish.
If you need more protection and want to follow up with a coat or two of poly before the wax, general finishes Arm-R-Seal that Chris recommended is the way to go
-- http://www.etsy.com/shop/KandJWoodCrafts
