Disc/Belt Sander
Forum topic by phk posted 306 days ago 939 views 0 times favorited 19 replies Add to Favorites Watch
View phk's profile
phk
15 posts in 572 days
306 days ago
I want to add some kind of stationary sander to my shop. I have a long, narrow shop (equivalent to a 2 car tandem garage) so while I have some space, the arrangement of things is a little odd. I don’t think I really have the space for a combination disc/belt sander because you need to be able to get to it from at least two sides to work with it. I’ve been leaning towards just getting a 12” disc sander but I’ve noticed on this site that many of you are literally in love with the Ridgid EB4424 Oscillating Edge Belt / Spindle Sander. I don’t have a special need (I don’t make guitars or anything like that). I’m just looking for a good general purpose stationary sander. Any thoughts on the best way to go here?
-- PHK - Martinez, CA
19 replies so far
View dbhost's profile
dbhost
4748 posts in 1398 days
#1 posted 306 days ago
There is a reason we like the EB4424. It does what it does VERY well…
View Jim Finn's profile
Jim Finn
1062 posts in 1088 days
#2 posted 306 days ago
I have a 6” x 48” belt sander from Harbor freight ($200) and use it a lot. It has a disk sander with it but I never use that. (Burns the wood ). This is the most used tool in my 10’ x 25’ shop.
-- In God We Trust
Gerald Thompson
192 posts in 401 days
#3 posted 306 days ago
I had a Dewalt 6’‘X48” disc/belt sander. I used it some the first year and I could never get good results. It sat idle in my shop for 10 years and I just gve it away. I now use hand planes, BS, spoke shaves, scrapers, etc., and do much better work.
-- Jerry
View Cole Tallerman's profile
Cole Tallerman
355 posts in 351 days
#4 posted 306 days ago
go for a belt/disk with a mobile base. The base will let you pull it away from the wall to get at all those angles you need around it. Also if you do, go for a 6×48 because most of the 4×36 sanders are crap and underpowered.
View crank49's profile
crank49
2276 posts in 1137 days
#5 posted 306 days ago
I use my 12” disk about as much as the belt.
Would hate to be without either.
If I was starting over, I’d carefully consider the Ridgid EB4424 Oscillating Edge Belt / Spindle Sander and still get a separate disk sander. They all do different jobs and I presently don’t have a spindle sander except for my drill press.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View gfadvm's profile
gfadvm
6611 posts in 856 days
#6 posted 306 days ago
I have an OLD Grizzly 6×48 sander and it gets used on every project. The belt gets used a lot more than the disc as I get less burning on the belt. i also have a Hatichi 4×36 that has held up well but is a toy compared to the old Grizz.
View rance's profile
rance
3855 posts in 1327 days
#7 posted 306 days ago
Andy, and others,
Get yourselves a belt cleaner:
http://www.woodcraft.com/product/2000271/8/abrasive-belt-cleaner-2-x-2-x-12.aspx
I’m sure Rockler has them also. Or just use an old tennis shoe.
View lumberjoe's profile (online now)
lumberjoe
2396 posts in 414 days
#8 posted 306 days ago
I was going to ask yesterday, why do I need one of these? My next tool purchase will either be something like this or a drill press. I guess I don’t really understand their use. What makes these better than just a regular old ROS?
-- http://www.etsy.com/shop/KandJWoodCrafts
rance
#9 posted 306 days ago
Joe, Put a 36 or 50 grit on the belt and you can do some shaping in a real hurry that will take a long time with a ROS. It has a purpose that is different than a ROS. It also has a table that gives you 90 degrees from the belt to square up corners if you need that. Grits are easilly and quickly changed.
View Bill White's profile
Bill White
2601 posts in 2127 days
#10 posted 306 days ago
Ridgid in my shop. Its a keeper.
Bill
-- bill@magraphics.us
View helluvawreck's profile
helluvawreck
10363 posts in 1033 days
#11 posted 306 days ago
I have recently put $250, including tax, and extra warranty, into a Harbor Freight belt disc sander. So far it’s been a good deal. I was considering a $500 sander that Grizzly sells. However, I was really pushed for money at the time. So far I haven’t been sorry. If it will last me a couple of years I will be happy because I was doing a whole lot of hand sanding and I consider it has already paid for itself in time saved in the last 6 weeks. I would probably still not have any sander yet so getting this cheaper one has helped me a lot. BTW, I put mine on a plywood base with casters because my shop is small too.
helluvawreck
https://woodworkingexpo.wordpress.com
View Alexandre's profile
Alexandre
1417 posts in 357 days
#12 posted 305 days ago
Rance, a Art eraser does a good job also.
-- My terrible signature...
gfadvm
#13 posted 305 days ago
Rance, I have three of the big gum erasers (one near every sander). They save a lot of paper. Joe, These sanders do so much more than a ROS: sand a perfect circle, true up a miter, round corners, take the excess ‘pin’ materiel off box joints, etc and they do it FAST!
lumberjoe
#14 posted 305 days ago
I’m just having trouble visualizing how they work, especially the belt part. I will probably get one this weekend. Woodcraft has there 10/15% of sale Saturday and Sunday
gfadvm
#15 posted 305 days ago
Joe, A big advantage to the larger sanders is a much longer platen under the belt. This allow you to sand/flatten longer pieces. The platen on my Grizz is 17” so check this before spending your money.
