Holes
Forum topic by brad posted 37 days ago 195 views 0 times favorited 13 replies Add to Favorites
View brad's profile
brad
112 posts in 339 days
37 days ago
Topic tags/keywords: question tip
*I know there are several ways to accomplish this task. My question is: what is the best way to do it , be able to repeat it, and do it time after time.
Here is the situation: a piece of hard wood approximately 7” wide and 8” tall by 3/4” thick.
The task: Cut a 2 1/4” hole in the center of the piece of hard wood.
-- Brad,--"The way to eat an eliphant is one bite at a time"
View Roper's profile
Roper
305 posts in 148 days
37 days ago
go pick up a 2 1/4 boring bite for your drill press.works great.
-- Roper - master of sawdust-
View tenontim's profile
tenontim
796 posts in 179 days
37 days ago
Draw an “x” on the board from corner to corner. That’s your center. Make yourself a table top to attach to your drill press table and put two fences, at 90 degrees of each other, so that the center of your “x” is centered under your 2 1/4” drill bit. You can also get a forstner bit that size.
-- Tim -- http://tmuli.com
View Partridge's profile
Partridge
152 posts in 391 days
37 days ago
1. I to would lean towards my DP but with a hole saw or maybe a circle cuter.
2. I would also make a cradle (to fences 90% to each other on a peace of plywood) clamped to the table of your DP.
This would give you repeatablity
-- Do it right the first time. Becuase fixing it is a wast of time.
View GaryK's profile
GaryK
8392 posts in 423 days
37 days ago
tenontim has it right about drawing the ‘X’ as long as your board is square to start with.
Drill the hole with whatever means you have.
View bbqking's profile
bbqking
175 posts in 158 days
37 days ago
Center it up. 2 1/4” Forstner. bbqKing
-- bbqKing, Lawrenceville
View Sawdustonmyshoulder's profile
Sawdustonmyshoulder
87 posts in 63 days
37 days ago
I did this using a plunge router and with a straight bit and collar. I had to make a 2 3/4” hole for clock face http://lumberjocks.com/projects/8229 and I only had a Forstner bit set to 2 1/8” maximum. What I did was to drill a 2” hole in a piece of 1/2” MDF with my Forstner bit. Then I used my 1/2” rabbet bit to cut a 1/2” rabbet in the 2” hole 3/8” deep. Then I used my flush cut bit to route the rabbet flush. That makes the hole 3” wide. I put a 1/2” spiral bit with a 3/4” OD collar (this gives you an 1/8” clearance between the collar and bit and a hole that is 1/4” smaller than your template) and after using the 2” Forstner bit to cut an initial hole in the project, I cut my 2 3/4” hole using the router.
I know that’s a whole lot of cutting but without that 2 3/4” Forstner, this got the job done. Brad, I hope this helped you either to get the job done or to warn you not to read too much into blogs. :-)
Good luck. Next time I was in WC in Franklin, TN, I picked up that big ole drill bit.
-- Makin' Sawdust!!!
View brad's profile
brad
36 days ago
FYI
Write,read,spell check, and then re-read…I violated my own rules. Thanks for the suggestions. My mistake when I wrote this post was that i misstated the problem. The hole i need to make has 2 3/8 Radius. The suggestions still apply I’m sure.
By the way “Beautiful walnut clock” sawdust
Sawdustonmyshoulder
87 posts in 63 days
36 days ago
Oh, yeah. That’s quite a bigger hole. Then, I would get out my homemade circle cutting jig for my router and make my template with it. I would cut out the hole in the MDF but don’t cut all the way through the MDF. I would drill a 1/2 inch hole near the cut part and finish making the template with a flush trim bit.
Thanks for the kudos on the clock.
tenontim
36 days ago
Ok, all of the above and here’s the link for your bit.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/forsbit.htm
View Slacker's profile
Slacker
111 posts in 136 days
36 days ago
I bought a jig for the router to make larger diameter holes. Use a 1/4” spiral bit. Found it at Woodcraft. Works like a charm. The X will mark the spot to make a centered hole.
-- There are three kinds of people... those who can count, and those who can't
View sIKE's profile
sIKE
401 posts in 189 days
36 days ago
Good link Tenontim, if this is a one off project and the direction you are going to go (forestner), you do not need the carbide tipped one. I picked up one at my local woodcraft for around the same size. I think this is a common size for clock inserts. The nice thing is since it is a Forestner bit you can cut half circles with it also, and hog out material from larger circles….
View Grumpy's profile (online now)
4659 posts in 286 days
35 days ago
If you have a drill press make a fence for for it with a stop clamped at one end. Once you get it right it will be the same every time.
bbqking
35 days ago
Center it up. 2 3/8” Forstner. bbqKing
Bookmark And Share This Page
