Forum topic by swordfish | posted 07-16-2012 05:49 PM | 2275 views | 0 times favorited | 4 replies | ![]() |
Does anyone know how to drill a hole through a log 4’- 5’ long. I’m trying to make a floor lamp but for the life of me, i can’t figure out how to drill the hole all the way through a log, especially if there is a twist or turn along the way. Is there a special tool that i need? |
#1 posted 07-16-2012 06:50 PM |
I have acomplished this task by sawing the piece in half and then routing a 1/2” wide dado 1/4” deep in each half. When you glue them back together you have a 1/2” by 1/2” hole to pull your wires through. I don’t know if this would work in your case or not. |
#2 posted 07-16-2012 07:03 PM |
Thanks. It’s been driving me nuts trying to figure out how manufactures of floor lamps get the wire all the way through, especially when dealing with Twisted Juniper. I have made several table lamps using an 18” bit, from driftwood, Walnut and cedar but i would love to learn how to make a floor lamp and not have the wire showing or a cut seam. |
#3 posted 07-17-2012 12:47 AM |
I have a 36” long 1/2” drill bit, could be used from both sides to get to 5’. But that is for straight stock, not sure how to do it with curvy stock. There was a project on here where the guy made a curvy lamp, but never revealed how he did it. -- Crashn - the only thing I make more of than sawdust is mistakes |
#4 posted 07-17-2012 01:17 AM |
I have done something like this… used a 16” long drill bit and then dug back in with an extender on it.. and then attacked in the same pattern from the other side.. and then poked around until I met in the middle. It’s not pretty, but you can’t tell. -- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28055 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
