unisaw frame motor mounts
Forum topic by calvin13 posted 07-16-2012 08:39 AM 3678 views 0 times favorited 3 replies Add to Favorites Watch
View calvin13's profile
calvin13
20 posts in 2048 days
07-16-2012 08:39 AM
Want to change 1.5 hp motor on unisaw to 4hp . Saw has 143Y frame mount . New motor has 145Y frame mount .What is the difference? will mnew motor mount up?
3 replies so far
View MedicKen's profile
MedicKen
1610 posts in 3369 days
#1 posted 07-16-2012 08:50 AM
Check out this chart to see of the mounting dimensions are the same
http://www.engineersedge.com/nema_frames.htm
View toolie's profile
toolie
2106 posts in 2535 days
#2 posted 07-16-2012 07:27 PM
i think the 145 may be for left tilt saws. i’d contact the sawcenter. if it’s unisaw related, they know about it:
http://www.sawcenter.com/
also, these guys seemed to be pretty knowledgeable about unisaw motors and mounts, and had the most reasonalble prices i could find on unisaw compatible leeson motors:
http://cgi3.ebay.com/ws/eBayISAPI.dll?ViewUserPage&userid=electricmotorsite
HTH.
View MrUnix's profile
MrUnix
6355 posts in 2106 days
#3 posted 07-17-2012 02:49 AM
Based on the NEMA specs, the 145 mounting holes are about an inch further away from each other than the 143 lengthwise. Everything else looks the same. If you have holes already drilled for the longer base then you are good to go, otherwise you may have to drill some new ones.
