need advice on how to do a two tone finish
Forum topic by localpref posted 310 days ago 381 views 0 times favorited 3 replies Add to Favorites Watch
View localpref's profile
localpref
5 posts in 310 days
310 days ago
Hi I am looking for some advice on how to acomplish something. I am making set of storage shelfs (basicly an open cabnit with a face frame) that have an oak face and plywood sides top and shelfs. The top of the sides will also have a small 1/4 band of oak the edge on the top.
What I would like to do is finish the oak bits the facing and edge band with a dark stain then leave the plwood natural and use a clear poly on the whole thing. Can I assemble the whole thing then tape off the oak bits or will it bleed onto the plywoood? If this sounds like a bad idea what would be a better way to acomplish this?
3 replies so far
View KnickKnack's profile
KnickKnack
805 posts in 1735 days
#1 posted 310 days ago
If you’re wanting the oak to be darker – have you considered fuming it with ammonia instead of staining it?
After fuming you can still do a little work, such as sanding flush, on the oak, without “cutting into” the darker colour.
Just an idea – I’m personally very fond of fumed oak, so I’m biased.
-- "Do not speak – unless it improves on silence."
View jmos's profile
jmos
637 posts in 538 days
#2 posted 310 days ago
You can stain the oak before assembly. Mask of any surfaces that will get glue and stain. Assemble everything and then clear coat the entire unit.
You could assemble, mask off the ply and stain, but I would be worried about getting some bleeding onto the ply, which you would probably not be able to sand out without blowing through the top ply.
-- John
View Michigander's profile
Michigander
101 posts in 588 days
#3 posted 310 days ago
Follow John’s advice and stain before assembly. I am completing a TV cabinet that I did this way. In fact I put on the top coats of Polyurethane too.
Michigander
