Skil Router 1825 works intermittently
Forum topic by Rove posted 07-15-2012 03:57 PM 1528 views 0 times favorited 7 replies Add to Favorites Watch
View Rove's profile
Rove
4 posts in 2141 days
07-15-2012 03:57 PM
Hi
I have a Skil 1825 router and it worked fine till my last project. Now it starts and stops intermittently and sometimes doesnt reach its max speed. Sometimes it slows down and stops half way thru routing. I am setting the depth of cut to 1/16. Does anyone know the cause of this problem?
7 replies so far
View jmos's profile
jmos
827 posts in 2369 days
#1 posted 07-15-2012 04:04 PM
You might want to check the switch, might have some sawdust in it preventing good contact. A loose electrical connection could also cause that. Hopefully the motor isn’t on the way out.
-- John
117091 posts in 3576 days
#2 posted 07-15-2012 04:31 PM
Check your brushes in the motor.
View Rove's profile
Rove
#3 posted 07-15-2012 05:54 PM
Thanks John & James. I will check the electrical connections and the brushes.
View Greg's profile
Greg
330 posts in 2872 days
#4 posted 07-15-2012 05:58 PM
My guess, if not brushes, would be the cord. Many times, I have found on older or well-used tools, that there is a break inside the cord which, when bent just the right way, causes an open circuit. Also, the fact that so little copper is actually carrying electricity across the gap, there is an amperage loss which could explain the power drop issue. Please let us know what you find. Good luck!
-- You don't have a custom made heirloom fly fishing Net? http://www.Sierra-Nets.com
View Rove's profile
Rove
#5 posted 07-15-2012 11:40 PM
The router is new and has been used sparingly. So it highly unlikely that the cable is faulty. It probably is the brushes as James as suggested as I see the occasional spark from the upper vent. Tomorrow, I will take it to the service centre. Hopefully the motor is not damaged.
Thanks guys for all your inputs.
View lumberjoe's profile
lumberjoe
2899 posts in 2247 days
#6 posted 07-16-2012 01:46 PM
Do you use an extension cord, or plug it directly into an outlet?
View Rove's profile
Rove
#7 posted 07-18-2012 12:31 PM
Latest update…. The service centre has confirmed that its the brushes that is causing the problem. Expect it to be fixed in a couple of days and I should be on my merry way making sawdust again !
Thanks a lot guys for your suggestions.
